Old 10-11-2005, 04:22 PM
4ophenia 4ophenia is offline
4ophenia is off the scale
If so, how easy/difficult was it getting those lugs off using the stock emergency kit?
2006 H3 Adventure/ Yellow/ Ebony/ 5-speed/ Black Brush Guard/ Black Tubular Steps/ Mud Flaps/ Black Crossbows/ Trailer Pkg/ Monsoon/Hadley Chrome Dual Air Horn
Repressed as a child, but no more ....
Old 10-11-2005, 04:50 PM
It is so easy, I just hold my phone up to my mouth and say "Call triple A"
Sorry, it was just to easy to pass up and I don't have an answer for you.
Old 10-11-2005, 05:10 PM
Yeah, I'll probably end up calling AAA too!! I guess it's just the Boy Scout in me - I want to be prepared and able to handle it myself.
Old 10-11-2005, 05:20 PM
SledgeHummer SledgeHummer is offline
SledgeHummer is off the scale
I had to change one, rear passenger side. let me put it this way, it took me more time to get the gear out of the rear door and open all the plastic and rubber covers than the time it took me to get the lugs off, REAL EASY, then it took me DOUBLE the time to put every damn thing back in place
SledgeHummer
Old 10-11-2005, 05:32 PM
Wow! Great to know. Thanks SH!
Old 10-11-2005, 05:48 PM
CLGeorge3944 CLGeorge3944 is offline
CLGeorge3944 is off the scale
I have had to change two tires, one in the front and one in the rear. Both times due to them being slashed here in lovely Baltimore. The hardest part is figurin out how to put the jack back together. Jacking it up & down was very easy both times! The jack goes together very nicely. I would say better then the one on my Ford and Toyota.
Old 10-11-2005, 07:22 PM
fourfourto's Avatar
I carry tire plugs and 12 volt air pump havent used factory jack for many years. why would you call(and pay for) aaa when all h3 have onstar with roadside assistance just press the button
Old 10-11-2005, 08:03 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by fourfourto:
why would you call(and pay for) aaa when all h3 have onstar with roadside assistance just press the button </div></BLOCKQUOTE>
Just because I already have AAA but don't have my H3 yet
Once I get the H3, then OnStar it is.
Old 10-11-2005, 10:34 PM
It's not that hard, matter of fact, first week I had a flat tire, called AAA, waited 10 minutes and they change the tire in 5......simple - he he
Old 10-11-2005, 11:16 PM
jkH1+H2=H3 jkH1+H2=H3 is offline
jkH1+H2=H3 is off the scale
On Star!!!
Old 10-11-2005, 11:21 PM
I carry tire plugs and 12 volt air pump havent used factory jack for many years. why would you call(and pay for) aaa when all h3 have onstar with roadside assistance just press the button </div></BLOCKQUOTE>
Yeah. Still getting used to the convenience of having OnStar. Before this I had a 94 Volvo 850 Wagon. No OnStar there. Hey, how long does it take to pump the H3 tire with the 12 volt? Quicker than the roadside assistance I'm sure, but just curious.
Old 10-12-2005, 03:23 AM
H3 Hummer's Avatar
H3 Hummer is off the scale
How heavy or hard is it to lift the tire up on the lugs?
Old 10-12-2005, 05:34 AM
Yeah, I have to admit, tire's a bit heavy, maybe not for Gov. Shwarzenegger, but a bit for me, a friend had to help me
SledgeHummer
Old 10-13-2005, 01:18 AM
H3 Hummer's Avatar
So sledge. I am a wimp and can lift with my legs but I don't have any upper body strength. I weigh about 115. I don't want to take a tire off and not be able to put the damn thing on the lugs. How much do you weigh? If you are stronger then me and had a friend help you I will wait for OnStar.
Old 10-13-2005, 02:10 AM
Hey H3,
fourfourto mentioned it earlier, but plugs and air pump might be another option.
Old 10-13-2005, 02:12 AM
LOL, I just read my post quickly. Not to be confused with butt plugs.
Old 10-13-2005, 11:29 AM
CLAYDOG CLAYDOG is offline
CLAYDOG is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3 Hummer:
So sledge. I am a wimp and can lift with my legs but I don't have any upper body strength. I weigh about 115. I don't want to take a tire off and not be able to put the damn thing on the lugs. How much do you weigh? If you are stronger then me and had a friend help you I will wait for OnStar. </div></BLOCKQUOTE>
The trick I've always used for tire changing is to only jack the car/truck up just enough that the studs are lose in the wheel. Then your not lifting the new tire, just locating it on the studs.
Old 10-13-2005, 12:16 PM
fourfourto's Avatar
another way when in a bad spot is fix a flat in a can if you can work a hairspray can you can use fix a flat. it sometimes hard to plug tire if you havent done it before. i would get 2 cans being that H3 tires are big than following day have tire fixed.
Old 10-13-2005, 12:21 PM
I read an earlier thread that cautioned against using cans b/c it screws up the tire pressure sensor.
