Old 06-01-2003, 07:10 PM
Does anyone know if the CTIS compressor in the Hummer H1 be used to connect a hose for filling up, say, the tires of other cars/trucks or equipement?
Obviously the H2 air suspension compressor /can/ be used for such things, I'm just curious about the flexibility of the H1's compressor.
Thanks.
Thanks.
Old 07-24-2003, 04:07 PM
Manny Manny is offline
Manny is off the scale
Yes.. it has a regular schrader valve output for auxiliary use at the side of the hood, and comes with a female schrader to schrader hose as well...
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by H2X0R:
Thanks.<HR></BLOCKQUOTE>
Old 01-09-2004, 02:31 PM
The kit and hose should be in your truck somewhere unless you bought it used then there's the possibility the old owner walked off with it.
Old 01-11-2004, 04:28 AM
Neverenuf Neverenuf is offline
Neverenuf is off the scale
Yes but before using it you have to isolate (sp) ctis on all wheels first or your tires will go flat
Old 01-13-2004, 03:51 PM
AirMissle AirMissle is offline
AirMissle is off the scale
lol, if they go flat, just disconnect whatever you attatched to the pump, and let it fill the tires
Clark Haskins
1996 TurboDiesel HMC4
2003 Supercharged H2
Clark Haskins
1996 TD HMC4
2000 TD HMCO
clark@flyinghummer.com
