Old 01-08-2006, 12:16 AM
Here are some various stages of Bebe-rhino project.
Disassembled...
The mud from Black rock was inside my inner fender well....
Front end assembly...
I'm going to be finishing up later tonight and tomorrow.
Old 01-08-2006, 12:26 AM
DAMN!!!!!!!!!! That looks great HummBebe!
Do the grill too!
Old 01-08-2006, 12:27 AM
lookin good
Old 01-08-2006, 12:29 AM
Waxing's Avatar
Waxing Waxing is offline
Waxing is off the scale
Looks great. I like it alot.
Old 01-08-2006, 01:29 AM
can't wait to see it on the 21st!
Old 01-08-2006, 01:22 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
Very unique. I like it. Good job!
____________________________
Old 01-08-2006, 02:14 PM
DarthKarl's Avatar
DarthKarl is off the scale
I like the look. Very Nice
Old 01-08-2006, 02:39 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
Much better in black than the white police cruiser we saw posted earlier.
WWW.BCBI.COM
Old 01-08-2006, 06:55 PM
ETD's Avatar
ETD ETD is offline
ETD is an unknown quantity at this point
That really looks good.
Old 01-09-2006, 01:29 AM
Humm3r Humm3r is offline
Humm3r is off the scale
Looks good on black! Good call.
Old 01-09-2006, 01:51 AM
All I have left to do now is the inner fender wells and the rockrails....then she will be fini!
I'll try and get some better pics, it looks almost sparkley in the sunlight
No extra parts so far
Old 01-09-2006, 02:14 AM
nmikes nmikes is offline
nmikes is off the scale
looks awesome... I'm going to get this done with mine eventually. Can't wait to see what it looks like when your done.
Old 01-09-2006, 10:56 AM
Ipedog's Avatar
Ipedog Ipedog is offline
Looks good HummBeBe!
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
Old 01-09-2006, 01:47 PM
evomind evomind is offline
evomind is an unknown quantity at this point
what did u use to make those black?
arent they molded in that greyish color? meaning that if u paint it and it chips, the underlying color will be exposed?
looks good. ive wanted to do that to mine, but wasnt sure abt the issues i addressed.
Old 01-09-2006, 02:47 PM
I took all of the plastic parts off, and then took to the local Line-x shop. So every Grey plastic piece now has line-x on it. I also did the fenders,rock rails and the brush guard.
It looks great, I was surprised at how simply everything is put together.
However, the line-x makes it a little more complicated to re-install. I am needing to gently sand/file the bolt holes to get some of the clips to fit.
Oh well, it's taking a little bit longer than expected to reassemble, but the fit and finish still looks great!
Thanks for all of the compliments
Old 01-09-2006, 08:39 PM
Mr. I - Man's Avatar
That looks hella sweet. Nice ride!
Old 01-09-2006, 10:28 PM
humvee humvee is offline
humvee is off the scale
Did you have to take off and replace the rubber that goes around where the fender meets the body or was it left on and masked off when sprayed? And how did the fenders that are attached to the rear door come off? I was told that when you unbolt them there are two clips that still hold them on and you have to cut them and replace when putting them back on?
I would appreciate the info
Looks nice!!
Old 01-09-2006, 10:56 PM
Left and masked/wired when sprayed. It is secured to the fender with glue.
There are 4-5 small bolts that secure the 1/4 fender to the interior of the rear door. There are also clips that are used to secure to the exterior of the rear door. The best way to remove the clips, is to use a long pair of needle nose pliers. Pulling the fender away from the body gently, slide the pliers down and pinch the clip to release.
If you do break them, you can purchase them from Hummer. Also, the clips for the front flares will work for the back. Don't lose the rubber washers
Old 01-09-2006, 11:28 PM
Thanks for the info!!!
Old 01-10-2006, 01:48 AM
hows it comin along , got er back together yet lookin forward to seein it on the run more pics
