Old 01-30-2006, 11:27 PM
Klint's Avatar
Klint Klint is offline
Do not use it, screws up your air censore and you wil have to replace it.
Klint T.
2007 Black Lux, Blinged out
Klint's Avatar
Klint T.
Old 01-30-2006, 11:33 PM
Hope you didn't try it!
Very true, but if it is the last resort (that or walking a few hundred miles), the sensor is only about $50.00.
(Besides, fix-a-flat also causes out of balance issues, but again, there are times it might be necessary.)
Old 01-31-2006, 02:17 AM
bparker's Avatar
bparker bparker is offline
LOL
http://www.tahoeforum.com
http://www.motoforum.com
Old 01-31-2006, 02:18 AM
bparker's Avatar
Also, for the record you CAN use Tire Jack made by Prestone. AutoZone sells it. It is acrylic based and wont mess up your tires and or sensors.
Old 02-01-2006, 09:04 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by bparker:
Also, for the record you CAN use Tire Jack made by Prestone. AutoZone sells it. It is acrylic based and wont mess up your tires and or sensors. </div></BLOCKQUOTE>
Have you tried it? I have to say fix-a-flat works for emergencies. I have been able to plug while on vehicle and not use the fix-a-flat in many year, but in case of an emergency, I would not worry about a $50.00 sensor. However if this stuff works as good, and does not mess up a sensor, this old guy might prefer to use this than lay on the ground and plug a tire.
Old 02-01-2006, 01:22 PM
bparker's Avatar
Yes, I had to use it twice in my old Z06. Its handy stuff!
I had the sensors installed and the monitoring option turned on in the PCM with a Tech-2. So i was able to get off the road before I went flat and I always kept 2-3 bottles of the Tire Jack in my rear compartment.
Old 02-01-2006, 07:43 PM
I had the sensors installed and the monitoring option turned on in the PCM with a Tech-2. So i was able to get off the road before I went flat and I always kept 2-3 bottles of the Tire Jack in my rear compartment. </div></BLOCKQUOTE>
Good information, I have to get a couple cans.
Never had a flat in any of my Vettes, and never ran the run-flats; except from the dealer to the tire store.
