06-21-2005, 12:52 PM
Hi there, I Own a Hummer H2 and the other day i went out to it and the battery was flat. i charged it back up and now you can still hear the fan inside running even with the keys out of the ignition. any ideas?
06-21-2005, 07:28 PM
Take it to the dealer. What else are you gonna do? You could always trying smacking the console like an old television. lol
06-22-2005, 03:16 PM
A direct short to ground on the blower motor circuit. This could be caused by a leaking battery corroding wires under the hood, a common ACDelco battery issue.
06-22-2005, 03:21 PM
Pay no attention to this post, it isn't DRTYFN, it is someone named "CheeseDick" hacking and trying to start trouble. DRTYFN would insult you much more eloquently.
06-23-2005, 05:55 AM
Cheers, Do you know where abouts its likely to be, or possibly have a picture of all the wires?
06-23-2005, 08:53 AM
Its probably the blower motor module thats in the heater case.
2003 Pewter, SunRoof, Nav, AirHorns, 6 disc in-dash cd changer, B/U camera, ipod
06-23-2005, 01:02 PM
Is there anyway of checking if it is that?
06-23-2005, 07:46 PM
you would need a volt meter and a wiring diagram. The part only takes about a half hour or so to replace, so I would just take it to the dealer. I work at a gmc dealer and have replaced a few of them on yukons for the same condition. I dont know for sure if the hummer is same but i would think that it is. I never looked at mine to see.
06-23-2005, 07:53 PM
If you take down the right hush panel under the dash, you should see the blower case and the blower motor. There should also be a piece in the case with I believe with 2 harnesses coming out of it and 1 of them goes to the blower motor. Unplug it and the motor should stop.
