Old 09-11-2005, 09:18 PM
Nixxxster's Avatar
Nixxxster Nixxxster is offline
Nixxxster is off the scale
Hi,
My H2 just stalled on me and won't fire back up. Engine cranks but won't fire up. It sounds like there is no gas going thur the injector. Anyone else here had this problem before? The H2 only have about 2700 mile only had it onver a month.
05 Lux Suv
95 Ducati 916
Nixxxster's Avatar
Hi,
05 Lux Suv
95 Ducati 916
Old 09-11-2005, 09:55 PM
VTSTOMPER is off the scale
Is the fuel pump working? Some people have had something like this happen...might want to try a search.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-11-2005, 10:17 PM
Nixxxster's Avatar
Yea, try to search but no luck. I'm bummed out it was my baby. Never had a car do that to me yet. ISs hummer that bad??
05 Lux Suv
95 Ducati 916
Old 09-11-2005, 10:19 PM
No - Hummer is not that bad.
There are some fuses you can check - have you looked at those yet? I honestly am not too sure about what it might be. I have only hear ramblings here and there!
Old 09-11-2005, 10:21 PM
This is the one I remembered...
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/8...331005521#8331005521
Old 09-11-2005, 10:22 PM
Another - but older.
http://elcova.com/groupee/forums/a/tpc/f/5106011751/m/7...126061584#7126061584
Old 09-11-2005, 10:23 PM
last with TSB.
http://elcova.com/groupee/forums/a/tpc/f/5106011751/m/1...881097911#5881097911
Old 09-11-2005, 10:59 PM
Nixxxster's Avatar
Thanks Stomper for the response. Roadside just towed to the dealer. Have to wait until tomorrow to see what the found. Thanks again
05 Lux Suv
95 Ducati 916
Old 09-11-2005, 11:09 PM
Let us know - and keep us poster. Sad to hear about that...I would hate to see mine go via tow truck.
Old 09-11-2005, 11:53 PM
Nixxxster's Avatar
yea, tell about it it was a sad sight to see..
Never had a car towed before. I guess only you and I are online today. No other member response But we'll see what happens. Thanks VT for the support and help
05 Lux Suv
95 Ducati 916
Old 09-11-2005, 11:58 PM
Yeah, I am the only one on - or I need to cut down on my post whoring.
Best of luck with the truck.
Old 09-12-2005, 01:05 PM
I believe no one touched your thread because it could be a multitude of things from the MAF sensor to fruit shoved up your exhaust.
There are a couple of fuses that might have blown, but that's not the most likely issue unless there are bigger issues that caused it. You could have fuel pump issues as VT stated, bad grounds, to bad connections at the PCM, the MAF, to the ole restricted exhaust.
Old 09-12-2005, 01:35 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Nixxxster:
Never had a car towed before. I guess only you and I are online today. No other member response But we'll see what happens. Thanks VT for the support and help </div></BLOCKQUOTE>
So, if someone just happens to be a car psychic and knows what your problem is are you going to go out and fix it on the spot? Just take it to the dealer and have it fixed and then post what the problem was. Attention whore.
Old 09-12-2005, 02:27 PM
Efrain's Avatar
Efrain Efrain is offline
Efrain is off the scale
First thing to check when your car dies out on you is make sure you have gas in the tank! I've seen it happen.
Old 09-13-2005, 02:29 AM
Nixxxster's Avatar
Not an "Attention Whore" just wanted to see if anyone else had this problem or heard about it. I guess I was wrong about try to get info or input from fellow hummer owner on a hummer forum. My bad
05 Lux Suv
95 Ducati 916
Old 09-13-2005, 04:07 AM
I pee pee in your tanky.
