04-03-2006, 04:35 PM
I went to the Rhino lining guy here, which is the same as Line-x and he told me he couldn't do the grill and mirrors because they are plastic. I told him I've seen others do this and he said it wouldn't stick very good. Is this true? Anyone having a problem with it or is this guy lazy? I've seen pictures of some of you guys doing this.
04-03-2006, 04:41 PM
It sticks great! They have to sand the grill, then "mist" the product on for the first application. After that they apply as normal.
http://elcova.com/groupee/forums/a/tpc/f/5106011751/m/9...441078741#3441078741
04-03-2006, 04:50 PM
Nah, youll be fine like Ken said. They guy here with linex has done it a few times to grilles and said it turned out great. Im about to get mine done with linex.
03 White H2 with Banks exhaust, Volant intake, 4\" Rancho lift, 18\" black Rockstars, 37\" ProComp Xterrains, Roof Rack and lights and a lot of turning heads!
04-05-2006, 12:14 AM
If its Not properly prepped, It Will Peel. but if done right, no worries..
04-05-2006, 12:20 PM
I'm not sure if I understand you correctly, but Rhino is NOT the same as Line-X.
04-05-2006, 12:51 PM
For grills and such, I would think you would want Line-X. It ends up being a hard surfaced product. Rhino is applied cold under low pressure and it feels more rubbery after it is applied.
I like Rhino better in pickup beds and whatnot only because I personally like that rubbery texture. But I'm not sure how well that would do on a grill and such.
04-05-2006, 10:01 PM
you know I guess I just assumed they were the same product just a different name. Hmmmmm I guess I'll have to check into that. Thanks
04-05-2006, 10:34 PM
I knew it!!
04-06-2006, 12:23 AM
I knew it!!  </div></BLOCKQUOTE>  I resisted the temptation of saying anything about latex gimp masks  </div></BLOCKQUOTE>I haven't been shy about my rubber fetish. I thought I posted photos of me in my rubber suits..... where . are . they
04-06-2006, 02:46 AM
Line-X uses a primer that is made for plastic surfaces. I had to wait on a new local Mine-X shop to order this special primer, since I was the first to request plastic to be sprayed. They had just opened that new location at the time and didn't have nay yet.
I would not use Rhino on the grill. Not only is is more rubbery, but it also appears to be applied much thicker than Line-X for some reason.
04-06-2006, 10:15 AM
thank you guys for the info, I'll have to see if there is a Line-x guy here.
