Old 01-27-2006, 01:38 AM
MarK M's Avatar
MarK M MarK M is offline
ok, so is there a rear reservoir for the rear nozzle? Cause when I press the button no fluid comes out.
When I use the fronts it works, so I know I have fluid in the reservoir in front. Do I have a bum nozzle? I hear the motor cranking.
MarK M's Avatar
Old 01-27-2006, 01:40 AM
First Hummer is off the scale
THEY HAD A RECALL ON THE REAR WWASHER PUMP.
Old 01-27-2006, 01:47 AM
MarK M's Avatar
ah man!
i guess i didnt get the recall notice cause i just got the rig.
grrr. service time!
Old 01-27-2006, 02:15 AM
took mine to the dealer last week and they fixed it.
Old 01-27-2006, 03:20 AM
MarK M's Avatar
so irritating... but i have no choice... i'll schedule to have them look at it.
Old 01-27-2006, 03:23 AM
westhillsat's Avatar
I made the dealer check it before I picked mine up.
Mine was ok.
Love this site for all the great info. Salesman said I probably knew more about the H3 then he did. I told him I learned it all from this forum.
Old 01-27-2006, 04:17 AM
MarK M's Avatar
ha... dig this... i couldn’t stand that my washer all of a sudden didn’t spray the water. So went outside in the cold and looked under the hood. Opened the cap and saw that I was low in fluid. I guess enough to spray the fronts, but what I noticed was what looked like a black motor sitting higher then the other one. I said to myself.. I wonder if the is for the rear and the reason why I wasn’t getting water to the rear was the level was too low. Sooooooo I filled the reservoir up and low and behold that was it.
I guess when I went to my first Tahoe trip and recently wheelin in Hollister i used up all of the fluid.
so... i'm good for now! whew...
Old 01-27-2006, 11:30 AM
humdoug's Avatar
humdoug humdoug is offline
humdoug is an unknown quantity at this point
If you received the recall notice you should still go and get it replaced or sometime in the future you will push the button with no results.
The dealer fixed mine in 30 minutes.
O ya, don't forget to check the gas - when that runs out it not so fun
Old 01-27-2006, 04:08 PM
MarK M's Avatar
i'll keep an eye out.
