07-30-2005, 07:57 PM
Anyone know how to remove the H2 door emblem? I have the interior panels off the doors today and thought I'd pop the emblems and de-bling them. I expected to find a couple posts sticking through the door skin with clips on the back but NO. I can't see anything inside the door that holds them on or any place where they pierce the skin.
There is a cross-member (horizontal) at about the same height from the bottom of the door. Maybe the emblem is attached behind that?
Thanks in advance!
\'05 SUT
Thanks in advance!
\'05 SUT
07-30-2005, 10:13 PM
3M tape. You can use a hair dryer and some fishing twine or a plastic hook to get under there. THey pull off.
The emblems should be attached by foam tape. Use a hair dryer or heat gun to heat the tape and dental floss or string to break the seal. The emblem should come right off with no residue.
05 SUT Lux
07-30-2005, 10:39 PM
Thanks guys.
\'05 SUT
08-24-2005, 06:57 PM
Has anyone else tried this??? I heated the hell out of the emblem and when i went to pull it off it was like i was just going to be ripping the foam. It was not coming off "clean".
08-25-2005, 06:06 PM
Location: GAIN INFORMATION AND EDUCATION RELATING TO HUMMER H2\'S
I used a hair dryer along with a plastic spatula to lift the emblem as I was heating it. In that way, it lifted the adhesive without scratching the finish. Used adhesive remover to clean up residue..
08-25-2005, 06:23 PM
3m makes a nice adhesive remover. I have used auto wax on that crap before too. Worked out pretty well!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
08-25-2005, 07:05 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Snake II:
The emblems should be attached by foam tape. Use a hair dryer or heat gun to heat the tape and dental floss or string to break the seal. The emblem should come right off with no residue. </div></BLOCKQUOTE>
I have done what Snake said with the Dental Floss and the hair dryer on my ML. It works great, pull it tight and use the floss like a saw to remove
12-04-2005, 06:51 PM
If you remove the emblems, what should you use to put them back on?
12-04-2005, 07:11 PM
3M makes a emblem glue.
12-04-2005, 08:16 PM
Ours are black now.  Duplicolor Truck Bed liner available from your nearest auto parts store.
12-04-2005, 08:17 PM
ah man! I bet they will look nice on there!!
12-05-2005, 12:33 AM
Ours are black now.  Duplicolor Truck Bed liner available from your nearest auto parts store. </div></BLOCKQUOTE>
You painted them while on the truck? I thought I might paint mine after removing them but two emblems came off in two pieces each. So all three are off for good.
\'05 SUT
12-05-2005, 12:37 AM
Ken
let me know how they hold up painted. I'm thankfully off my chrome phase and going back to the way it was when I had the 03...blacked out!!
If they hold up well, Im gonna paint mine too....do you have any pics?
Im sure CP must have snapped some
12-05-2005, 01:06 AM
heres the rattle can KenP talked about
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
12-05-2005, 01:16 AM
Dupli color kicks butt!!!!
I love the wheel paint I used!!!!!
12-05-2005, 04:55 AM
I used an empty 12 pack container to mask the immidiate area around the emblem. The cardboard holds it's shape, is easily cut, and can be slid in-between the body and emblem, against the foam tape. I then used a couple of sheets of newspaper to mask the immidiate area around the emblem.
I sanded with an orbital for about 20 seconds each and wiped down with a damp paper towel. Smoked a cig and opened a Pepsi to waste time and make sure the emblem had enough time to dry.
Shot the emblem, fully coating it at one time. I didn't want to give the paint a chance to cure and peel when I removed the masking. Then removed the masking immediately.
There are a couple of places I need to touch up because I bumped the painted surface by mistake and some of the spray snuck under the cardboard. It's really not noticable, but I know it's there.
I also did the chrome license cap yesterday. :No pics because the battery needed to be recharged and I didn't want to wait.
12-05-2005, 05:17 AM
The chrome brow is a good idea also....I think Im going to take the risk and try and do both the emblems and the brow....wish me luck, Im jewish, and my people are historically bad manual laborers
