10-05-2005, 04:15 AM
Okay - I've looked on the WARN website and they offer a very cool looking, almost hidden winch/bumper setup for the H2. Is anyone using this? If not, what winch system DO you all use?
10-05-2005, 05:05 AM
I use a milemarker 12,000lb hyraulic winch. Its mounted in a cradle I can move front to back bumper.
Strong. Silent. 100% duty cycle. & contrary to everthing I heard before shopping, it cost about the same as an elctric winch once you added up all the bits and pieces.
It looks pretty butch too.
10-05-2005, 05:08 AM
I'm planning on the drtyfn winch... one of these days  Seen it up close and definately better than warn bumper..
'03 H2
10-05-2005, 05:10 AM
I am running the Warn Winch 9.5 TI.
10-05-2005, 05:29 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Arizona Hummerboy:
I am running the Warn Winch 9.5 TI. </div></BLOCKQUOTE>
How is it attached? Pics please?
Sean
10-05-2005, 09:09 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Bondage:
Okay - I've looked on the WARN website and they offer a very cool looking, almost hidden winch/bumper setup for the H2. Is anyone using this? If not, what winch system DO you all use? </div></BLOCKQUOTE>
10-05-2005, 10:43 AM
9000 lbs portable Ramsey Winch. I dont have make any kind of wiring inside.. I have cable short or long to connect in front or rear. The winch remain in the cargo area...
10-05-2005, 01:32 PM
Hey Paragon,
I see from your pic (NICE rig) that you're using the winch system I'm considering. Did you install it yourself? Does it interfere at all with the front approach angle? Any problems or concerns with it? Would you buy the same unit again? How much did you pay for it?
I really appreciate the info. I nearly got stuck in heavy, thick mud a couple of weeks ago going 5 miles across a supposedly "dry" lakebed in the desert. After tons of rocking, steering wheel swaying, and SWEATING, I got across. But I promised myself a winch and a Pull Pal before going back!
Thanks again,
Sean
10-05-2005, 02:33 PM
not mine..but nice...
'03 H2
10-05-2005, 08:53 PM
I just got quoted $2,040 for the bumper setup, winch, and installation. Sound about right?
Sean
10-05-2005, 08:58 PM
Approach angle.
10-06-2005, 11:37 AM
Sean </div></BLOCKQUOTE>
Which winch and bumper?
(Could be about right...)
10-06-2005, 01:41 PM
were you aired down in the mud? did you use low w/ tc2? I had simailar experience and took bout 45min of floorin & rockin to get out?
10-06-2005, 08:32 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by rusty:
were you aired down in the mud? did you use low w/ tc2? I had simailar experience and took bout 45min of floorin & rockin to get out? </div></BLOCKQUOTE>
I was aired down to 18psi, and using 4low w/tc2. This mud is like a heavy clay and very sticky, thick, and nasty. It took me some time too, and I was just glad to get out at all! Actually, some super moded Bronco had passed me coming the other way a few miles before I got to the lake and he said he and eight other vehicles (mostly Jeeps) had tried, failed, and gone back and around. He pointed to my Hummer and said, "I wouldn't try it in that."  After that, I HAD to do it.
Sean
10-06-2005, 08:35 PM
(Could be about right...) </div></BLOCKQUOTE>
The Warn H2 bumper kit and the 9.5xp winch.
Sean
10-06-2005, 11:07 PM
Still sounds about right.
10-07-2005, 01:59 AM
The Warn 9.5ti and multi-mount combo mount in your hitch receiver. Assuming you wire both the front and rear, you can use it from either end. More info here: http://warn.com/truck/winches/src/9.5ti.shtml
Edit: Wrong link. Should be http://warn.com/truck/winches/src/95ti_multimount.shtml
\'05 SUT
