Old 06-14-2006, 04:54 AM
H3 Hummer's Avatar
H3 Hummer is off the scale
Question Winch Question - What is your opinion...
In regards to a portable winch being mounted to a 2 inch. trailer hitch, if the hitch is rated around 5,000 - 6,0000 pounds and your winch is around 10,0000 pounds is this a dangerous scenario?
Old 06-14-2006, 05:10 AM
Default Re: Winch Question - What is your opinion...
The truck would move, or rather be pulled toward the object you were winching, before it would break.
Old 06-14-2006, 05:14 AM
H3 Hummer's Avatar
Thanks - chicks rule!
the trucks way 4700 - 5000 lbs depending on mods the extra power in the winch will be great just dont try to winch an H2 with it then you would want a frame mount
Old 06-14-2006, 03:06 PM
Aaron Kappler Aaron Kappler is offline
Aaron Kappler is off the scale
The winch is only as strong as the weakest point. I would advise against using such a mount.
I'm not sure if you have ever seen a winch cable break, or a tow mount break, but it is not pretty. Is it really worth the risk?
