06-08-2006, 06:32 PM
Roof mounted cargo box
Does anybody have a roof mounted cargo box? I was thinking about getting a Thule 682 so I can leave the spare in when I travel. The only question seems to be will the ubolts that attach it to the crossbars fit the beefy bars on the H2 rack?
06-08-2006, 10:07 PM
Re: Roof mounted cargo box
I have the "official" Hummer model (came with my used '03 H2... kept it!). It is a nice setup, and works well, if you choose to go that route. Hopefully, someone can answer the question specifically on the Thule...
___________________
05 Desert Sand H2 Adv
06-08-2006, 10:39 PM
The hummer one is made by Thule FWIW. I think the stock mounting hardware is 100mm u bolts. I don't have the catalog in front of me, but thats what I remember. Just go to you local Thule dealer or call the 800 number for Thule and they can get you all hooked up. I was going to do the same thing, but ended up sticking the tire on the rear. Yakima also makes a nice cargo carrier too, so you might want to check those out aswell.
06-08-2006, 10:59 PM
I was under the impression that Thule does NOT support using their products with the H2 and the factory racks (even though they supply the Hummer cargo box). If you want to use their products, you're supposed to use their racks. If you want the U-bolts, you may just have to go to Home Depot...or, I thought that the cargo box was attached with smaller bolts to the inside rail of the cross racks..?
'03 H2
06-09-2006, 06:19 AM
I got the bigger one! I need to get longer carriage bolts to make the hardware work though.
06-09-2006, 03:48 PM
Just don't forget to take it off and put it one outside the garage...  Unless you have an aircraft hangar.
~2005 Stealth Gray H2 SUV.
06-09-2006, 04:34 PM
Hehehe... I had a friend do that with his bike. Put it on his vehicle in an underground parking lot, and tried driving out....
'03 H2
06-09-2006, 04:37 PM
Haha, opps.  See, it should have been the HUMMER Tactical bike. It would have blasted a hole through the parking garage ceiling.
06-10-2006, 06:39 AM
After messing with the brackets for hours I finally figured it out. Just take the end of the roof rack off and pull out the rubber piece, then you can slide some carriage bolts in the track and just bolt the cargo box to the rail. Geez!
06-10-2006, 06:27 PM
'03 H2
06-11-2006, 04:15 AM
Thats exactly what I did with my Thule box and no problems. Thousands of miles with it up there and all is well
07-02-2006, 05:09 AM
I'm interested in purchasing the Hummer hard roof carrier... anyone selling theirs in So Cal?
