07-18-2006, 07:35 PM
What is in your BAG????
Putting together a recovery bad for going out on the trail.
Got the following, what else?
1. good quality strap
2. 2 d rings
3. gloves
4. small shovel
07-18-2006, 07:39 PM
Re: What is in your BAG????
Super absorbant towel
07-18-2006, 07:42 PM
why
07-18-2006, 07:43 PM
tools:
Basic sockets and socket wrench(extenders come in handy)
Pliers
Screwdrivers
Wrenches
Channel locks
Twist ties
Cotter pins
Electrical tape
48” Hi-lift jack
Heavy duty leather gloves
Mechanics gloves
Jumper cables
Safety glasses or goggles
Tire gauge
Electrical kit- wire terminals, terminal pliers, splicer/cutters
Hurricane tape
Fire extinguisher
Flashlight w/ extra batteries
Utility knife
Ratchet straps (2 or more)
extry tie-rods
recovery:
Tow straps - 3” (30,000 lb) and a 4” (40,000 lb) quality tow straps 30’ in length with loops at both ends. Straps with pre-attached tow shackles and 2” straps are not recommended.
Shackles - 7/8" shackles and 3/4" shackles
1" 30' synthetic snatch rope (33,500 lbs)
Spade or small shovel- foldable travel spades are available
Winch
Receiver mounted shackle
Snatch blocks (2)
1" 10' synthetic bridal/tree-saver rope (33,500 lbs)
tree-saver strap 2" 10' (20,000 lbs)
Small axe
Small tree saw
Nav gear, trail maps and tools
First aid kit juss in case
07-18-2006, 08:00 PM
Originally Posted by Alec W
I keep all of the above (plus some) in my truck vault:
biodegradable toilet paper
what other kind of toilet paper is there?
07-18-2006, 08:07 PM
why
To soak the water out of mudpits or streams before you drive through them.
'03 pewter base H2
07-18-2006, 08:11 PM
... a foot of rebar ...
What can you use this for other than as a blut club? Seriously.
...JB weld...
Is this for things like sticking your tierod back on your centerlink if it falls of?
'03 pewter base H2
07-18-2006, 08:15 PM
Add: - spare change of clothes
- rain gear
- spare meds if you take any
- spare key to give to others so you don't get locked out of the truck (if you don't have and trust onstar for this)
'03 pewter base H2
07-18-2006, 08:26 PM
07-18-2006, 08:35 PM
beer. Even warm it helps take the edge off the stress if you get in a bad situation.
07-18-2006, 08:55 PM
balls
07-18-2006, 09:01 PM
wondering who would fall into that one para! Thanks i had missed a few things, But some of this would leave no room for anything else?
07-18-2006, 09:17 PM
Air down valves, under hood compresor w/20 foot hose,floldable shovel,fire ext,tow strap,tire repair kit,first aid kit,jumper cables,2 air gauges,extra 25 foot air hose (for the beach air they only have 2 hoses and there are 10 connectors for air)A board for jack (so it dont sink in sand) 6 bungee cords,2 flashlights(1 shake light).assorted general tools ,tape ect in small carry bag,rags,AC Inverter,poncho,blanket and all of that is stored in the 3 rear compartments except the blanket its in net up against the rear seat and the airdown valves ,there the only thing that fit in the door pockets
07-18-2006, 09:25 PM
Bear spray, that is all.
07-18-2006, 09:28 PM
07-18-2006, 09:52 PM
Something better...S&W Model 500
07-18-2006, 10:23 PM
spare H3 front diff (only if wheeling with H3s).
You guys aren't over that yet? Sheesh? What's it gonna take?
