Old 08-14-2006, 06:24 AM
Default Check your bolts!!!
So we noticed Neo's truck was being extra squeaky today. When we got back to the house we were able to isolate the noise. The bolt where the back of the tranny attaches to the crossmember was loose.
So I get under mine to look at it and check the bolts on the skids, UCP, etc. I noticed one of the bolts for the front driveline where it attaches to the t-case was backed almost all the way out. I checked the other three and they were all loose.
So we both tightened everything up. I checked Bebe's truck and nothing was loose, and we'll check the others in the morning.
Just a heads-up for those of you that are out banging these things around.
Old 08-14-2006, 06:27 AM
Default Re: Check your bolts!!!
Good info for all of us. Enjoy the wheelin!
S.
Old 08-14-2006, 06:59 AM
They're probably line-x'd in. Works better that loctite.
Old 08-14-2006, 02:46 PM
garnerbiker's Avatar
garnerbiker garnerbiker is offline
garnerbiker is off the scale
The washboard in Death Valley rattled 2 skid plate bolts loose. I'm glad I heard them rattling around.
With these new rigs I recommend getting out the torque wrench and going over the vital area. I found others that were loose.
While you're checking your bolts, you might want to check the nutz too. Hahaha
[O][][][][][][][][O]
Old 08-14-2006, 03:58 PM
Tubs McFatty's Avatar
Tubs McFatty Tubs McFatty is offline
Tubs McFatty is on a distinguished road
Hahahahaha!!!!!!!!!!!
I plan to eat you.
Old 08-14-2006, 04:41 PM
TheArchiTexan's Avatar
TheArchiTexan TheArchiTexan is offline
TheArchiTexan is an unknown quantity at this point
hummbebe is very loose. Trust me on this one
Old 08-14-2006, 07:40 PM
Sounds like a few screws may be loose as well...
Old 08-15-2006, 01:58 AM
H3 Hummer's Avatar
H3 Hummer is off the scale
I had a two bolts missing and had to replace them. One guy had his skid plat fall off on the hi-way. This was last year I believe.
Old 08-19-2006, 09:01 AM
Klint's Avatar
Klint Klint is offline
Mine did that too sounds like the same bolt!
Klint T.
2007 Black Lux, Blinged out
Old 08-21-2006, 12:44 AM
check your NUTZ
