Old 08-22-2006, 09:42 PM
Default Stuck In The Mud & The Recovery
These are pictures from our last trip to The Ranch. After having driven around at a similar distance from the water at a different spot and finding the surface to be suitable for the weight of the H2 I drove out to look at a mysterious deceased bird(). As I turned to head back to drier ground I could feel myself starting to lose traction & momentum. I let off the gas, got out to survey the situation and decided I was only going to make it worse by trying to spin out of it. Trust me on this - I have LOTS of experience with this area(Antelope Sink)- at times it's a tank trap. After my buddy's H1(with 39" Iroks) failed to jerk snatch it out with a strap jerk we hook up the synthetic line to the H1 and started winching. I wasn't horribly stuck at first, but that changed soon enough. At first, all the winching did was drag the H1 towards my rig. Then, with the winch line pulled tight, the H1 spun its tires to dig in a little bit to anchor itself. The 12K Warn winch started to do its job. All I can say is that winch rocks. Because of where my H2 was positioned and the direction it was pointing, winching had to be done from a 70-80 degree angle at first. Since the H2 was basically being winched sideway, it started building up big berm of mud which increased the resistance. Lot's of shoveling & winching later the H2 was again free. After that we did cookies.
