Old 08-17-2006, 01:56 AM
Default bulletin
Subject: Itch or Squeak Type Noise Coming from Lower Drivers Door Area (Reposition Park Brake Cable) #06-05-26-002 - (08/15/2006)
Models: 2006-2007 HUMMER H3
Condition
Some customers may comment on an itch or squeak type noise coming from the lower driver's door area. This noise typically occurs when driving over uneven road surfaces.
Cause
The cause of this condition may be due to the park brake cable rubbing on the frame near the front left side body mount.
Subject: 4L60-E, 4L65-E Automatic Transmission Fluid Leak from Oil Pump or Bell Housing Area (Remove Burrs on Torque Converter Hub, Pump Drive Slots, Replace Torque Converter Hub-to-Oil Pump Seal Assem. (243)) #06-07-30-016 - (07/18/2006)
Models: 2006 Buick Rainier
2006 Cadillac Escalade, Escalade ESV, Escalade EXT
2006 Chevrolet Colorado, Corvette, Express, Silverado, SSR, TrailBlazer
2006-2007 Chevrolet Avalanche, Suburban, Tahoe
2006 GMC Canyon, Envoy, Savana, Sierra
2006-2007 GMC Yukon
2007 GMC Yukon XL
2006 Pontiac GTO
2006 HUMMER H2, H3
2006 Saab 9-7X
with 4L60-E or 4L65-E Automatic Transmission (RPOs M30 or M32)
Condition
Some customers may comment on an automatic transmission fluid leak. Upon further investigation, the technician may find fluid leaking from the oil pump or bell housing area. This leak may be very slight with only dampness of one or two drops of ATF observed at the bottom of the bellhousing.
Cause
Investigation of 2006 transmissions has shown small scratches or cuts in the torque converter hub-to-pump seal (243). These scratches or cuts may be caused by small burrs on the torque converter hub, pump drive slots.
Old 08-17-2006, 02:15 AM
Default Re: bulletin
we have had a couple of itches..easy fix...
Old 08-17-2006, 02:37 AM
deserth3's Avatar
deserth3 deserth3 is offline
Don't have that. But with the sunroof open the door lock lever rattles from the wind on the back door drivers side. Sounds like speaker buzzing when it happens.
Also above 95 deg, when the sunroof is closing it will stop and start to open by itself. Like it's sensing an obstruction.
Any fixes for these.
Old 08-17-2006, 02:43 AM
damn burrs!
Old 08-17-2006, 10:55 AM
Nothing in the bulletins, but the dealer should be able to fix. Rattle sounds like a simple adjustment or replacement of something that is broken. Sunroof sounds like a binding issue due to the heat expanding some plastic part. Probably a simple adjustment required.
Old 08-17-2006, 01:06 PM
deserth3's Avatar
Thanks. Figured I'd ask before I took it in. I just don't like taking it in for such minor things.
Old 08-17-2006, 11:32 PM
Hmmm2's Avatar
Hmmm2 Hmmm2 is offline
Thanks for the heads up, f5fstop.
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
Old 08-18-2006, 03:18 AM
Viet Nam Vette's Avatar
Thanks F5... "You Number 1".....(Remember That)..
Old 09-23-2006, 01:19 AM
Oh really, so how is it done? I tried moving it while I was under there the other day, what's the official method of doing it?
Old 09-23-2006, 02:17 AM
Tie strap to a brace to keep it away from the body mount.
Old 09-23-2006, 02:41 PM
2xtreme's Avatar
2xtreme 2xtreme is offline
2xtreme is off the scale
I have the brake cable issue then.
Old 09-25-2006, 04:53 PM
X2
Old 09-27-2006, 11:41 AM
F5,
Are you talking about a tie wrap? Which dimension and length do you reccommend?
