Old 07-26-2004, 12:53 AM
TroysH2 TroysH2 is offline
TroysH2 is off the scale
Should the bolt (connecting the lower pulley to the crankshaft I believe) rotate in a oval direction. The bolt or combination retaining washer seems to be out of place. More space on one side of the inner pulley than the other.
Would this cause a vibration from the front end and/or is this normal.
Old 07-27-2004, 01:21 AM
Yetti Yetti is offline
the best I can answer is this,..
your dealing with a stamped sheet metal pully put together by a machine, whitch intern finds the hole on its own...
I would gather its wobbling and your bothered by it?
I don't think its going to fall if its tight, and if its not then you should(tighten it)that is.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 07-27-2004, 02:16 AM
If Yetti is right and you are getting a wobble you must take it in... with a tow truck. The vibration could shake the engine to pieces. Let us know what happens.
Old 07-27-2004, 08:59 AM
HGW HGW is offline
HGW is off the scale
KenP is right. Get it fixed--do not delay.
