Old 10-11-2006, 08:45 PM
H3.007 H3.007 is offline
Default Auto Window Switch for Passenger Door?
Anyone know if it would be possible to install a window switch, similar to the driver's-window switch, which would automatically roll the passenger side window down with one touch?
If possible, associated expense?
Thanx!
Old 10-11-2006, 10:08 PM
marin8703's Avatar
Default Re: Auto Window Switch for Passenger Door?
I think this will do what you want:
http://www.directedstore.com/cgi-bin/commerce.exe?preadd=action&key=529T&reference=/cgi-bin/commerce.exe%3Fsearch%3Daction%26keywords%3Dall%26 searchstart%3D20%26template%3DPDGCommTemplates\Ful lNav\SearchResult.asp%26category%3DA_SE
its an module that is connected to the window switch. It will make it an exspress up/down switch.It can also be connected to the alarm (dont know which alarms) to roll up the window when arming the alarm. This costs $70. It allows you to contrl one window in 2 directions, or 2 windows in one direction. Theres another one, basically the same but can controll 2 windows in 2 directions.
Hope this helps
Marin
Old 10-12-2006, 01:14 PM
H3HUMMER's Avatar
H3HUMMER H3HUMMER is offline
H3HUMMER is on a distinguished road
I like to do the same thing.
Old 10-12-2006, 01:52 PM
Hey man,
Thanks for the information. THis would also work with the sunroof, yes? Very cool. I'll have to pursue this....
Old 10-12-2006, 03:01 PM
The one that controls 2 windows in 2 directions, or 4 windows in 1 is the 530T
http://cgi.ebay.com/CAR-ALARM-POWER-WINDOW-CLOSER-AUTOMATION-MODULE-530T_W0QQitemZ120039970558QQihZ002QQcategoryZ75389 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The 529T is for sunroofs.
Old 10-12-2006, 03:20 PM
Many thanks for the info guys. Has anyone actually done this and if so, did the owner do the install or did they have a garage do it?
Old 10-12-2006, 03:33 PM
I did the window automation on all 4 windows in a previous car myself. It's really easy, basically you just cut a couple wires inbetween the switch and motor and connect the 530t wires to each end. Just putting the module inline with all the switches.
I haven't done it on the h3 yet though, because... I'm almost positive you will have to run wires into every door, instead of just doing them all in the drivers kick panel. Not sure if you have ever noticed, but when you try to put the windows down you can hear a relay or something click in whatever door, you'll likely have to interface between the switch and that relay. You will have one-touch down from every window switch though if you go in every door.
