Old 07-09-2009, 11:06 PM
iccon's Avatar
iccon iccon is offline
iccon is on a distinguished road
Default inside noise
I have a rattling noise driver side, right close to the window sounds like a screw vibrating, anyone had similar problem and if so what the f--k is it.
only time I can hear it is when I driving down the freeway at 50 - 80 mph
Old 07-09-2009, 11:31 PM
SCB51861's Avatar
SCB51861 SCB51861 is offline
SCB51861 is on a distinguished road
Default Re: inside noise
mine is not rattling. Mine soundslike the windshield is coming out or has some major leaks. If there is a fix let meeeee know!!
need a RV? www.phoenixcruiser.com
Old 07-10-2009, 02:26 AM
Easy Ed Easy Ed is offline
Could this be the problem
http://www.elcovaforums.com/forums/s...ndshield+noise
Old 07-10-2009, 08:36 PM
iccon's Avatar
I will check and see if thats the problem
tk
Old 07-11-2009, 05:03 AM
pull your A pillar covers off (2 screws) and 3M tape them down. If you still have the issue, you have an air leak in the windshield. Also check your sunroof deflector. Those come loose and will rattle also.
,,,also just noticed you have lights up top. it may very well be your light wires making the noise. 3M tape will help that too.
Old 07-13-2009, 03:30 PM
iccon's Avatar
thanks I will get some 3m tape and try it
