Old 11-15-2006, 11:08 PM
aetherH3 aetherH3 is offline
aetherH3 is off the scale
Default Is there a way to tighten the cross bars?
The front cross bar is nice and tight but the rear one wiggles around a bit. Is there any way to tighten them?
Old 11-15-2006, 11:31 PM
Default Re: Is there a way to tighten the cross bars?
Make sure it is in one of the indentations. Loosen it and slide it back or forward and you will feel where it snaps into place. Then tighten.
Old 11-16-2006, 01:22 AM
I did that... that little lever just doesn't tighten it enough.
Old 11-16-2006, 02:15 AM
Hummer Guy's Avatar
Hummer Guy is off the scale
sounds like warranty...grab some new bars @ your dealer.
-Brian
http://www.hummerguy.net
Old 11-16-2006, 03:09 AM
H3slate's Avatar
H3slate H3slate is offline
Mine was a little loose after having a yakima gear basket on it. If you take off the locking cover there is a hex bolt you can tighten to stop the wiggling.
