Old 12-07-2006, 04:50 AM
Default Attn KenP: found a Jeep for ya
92 YJ Buggy. Mostly built by BTF
Has a clear Title.
Motor:Its an LT1 stroked, the Opti Spark has been eliminated.
Everything was brand new when the motor was built.
12lb Boost Vortech V-Trim Super Charger
Eagle Crank
6 "Eagle Rods
Chromolly Rings
J & E Pistons
Comp Cam
Comp Lifters Full Roller
Stainless Valves
Comp Roller Rockers
Titanium Retainers
7727 Gm Computer DR. K Custom Chip
35LB Injectors
8to1 Compression
MSD Ignition
I have the build sheet from the motor.
It has been balanced and blue printed, and ported and polished.
Has around 650HP at the crank.
Transmission: Built Manual valve body Turbo 350
Transfer Case: NP205 that has been twin sticked.
Axles: 2 ? ton Rockwells both steering axles, welded diffs .
Tires: 47? LTB?s
Wheels: 16.5x9.75 Stazwork Double beadlocks.
Steering: Up front it has a 10? Double Ended Ram from POS, outback it uses a single
Ended 8? Ram from Tractor Supply.
Suspension: 4 Linked front and rear. Uses Fox 16" Remote Coilovers.Links are 2" x .250" Wall DOM Tube and uses JMX16T heims.
The jeep works awesome.
Does not have a windshield!!
price $34,000
