Old 08-19-2006, 05:35 PM
jp's-h3 jp's-h3 is offline
Default ----------CUSTOM CENTER CAPS----------
Here's a custom little addition for the Hummer center caps.
Items needed:
1- spray paint
2- rubbing alcohol
3- cotton swabs
4- paper towels
5- adhesive romover
6- masking tape
7- news paper
8- scissors
Ok here we go!
First take off the center caps (all 5). Then dampen a cotton swab w/ rubbing alcohol and clean out all letters. Mask off around the letters (just mask off the basic outline). Using the newspaper, cut out around lettering so you dont get overspray on the center cap, and tape down.
Spray 3 light coats of paint over the lettering at all angles for complete coverage.Remove tape, Let dry for 10-15 minutes. Using a paper towel, lightly dampen with adhesive remover and rub over letters gently to remove any overspray (make sure you don't saturate paper towell, if you do you could very easily get the adhesive remover in the lettering and make a big mess). Yes my H3 is red and yes, what a great match!
That's it!, pop your center caps on and wha la, CUSTOM CENTER CAPS!
Old 08-19-2006, 07:31 PM
HumM3R'n's Avatar
HumM3R'n HumM3R'n is offline
HumM3R'n is on a distinguished road
Default Re: ----------CUSTOM CENTER CAPS----------
Nice Idea.
Thanks For The Share.
Smith & Ginn For Heisman 2007
Old 08-20-2006, 05:21 PM
Cool... Yours is red?
Old 08-21-2006, 06:13 PM
fourfourto's Avatar
Looks GR8 jp
I used a metalic silver scripto(all surface) ,it also worked.
Someone tryed it in yellow and it didnt cover.
Old 08-21-2006, 06:19 PM
fourfourto's Avatar
I also did the cross bars.
These pics were taken before I cleaned it up the following day.
Items needed:
1 metalic silver scripto permenent marker $2.99
GR8 minds think alike.
Old 08-21-2006, 08:12 PM
I don't like the black bar center caps, sorry but let us know how the marker works out.
Old 08-21-2006, 08:20 PM
Looks Great!
Old 08-21-2006, 09:11 PM
fourfourto's Avatar
I like the black bars over all silver.to each his own.
The marker held up now for 5 or 6 months.
I did touch up the wheel caps though,the dealer powerwash them real good.Stayed on just wore down a bit.
They didnt power wash the crossbows they still look fine.
Watch out jp
I beleve a power washer will also mess up the paint on the caps
Old 08-21-2006, 09:40 PM
HummBob's Avatar
HummBob HummBob is offline
Those caps(both) look sweet Great Job
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 08-23-2006, 04:18 AM
Watch out jp
If you take the time to do it right, It will last.
The pressure washer has had no effect what so ever!
Old 08-23-2006, 04:21 AM
Yes, It is Victory Red!
Old 12-15-2006, 03:21 AM
ictH3's Avatar
ictH3 ictH3 is offline
ictH3 is on a distinguished road
Looks GR8 jp
Mine are all silver so I ended up the just the opposite of yours.
I used flat black spray paint.
Old 12-15-2006, 03:33 AM
fourfourto's Avatar
Looks good with the black
Old 12-15-2006, 03:42 AM
ictH3's Avatar
Hey... Thanks! So does yours!!
Old 12-15-2006, 04:30 AM
fourfourto's Avatar
Use the leftover paint on your skidplate.
I did mine in low gloss black heat paint I had around for the 442
Old 12-15-2006, 08:26 PM
ictH3's Avatar
That does look nice! I?ve been thinking about doing that too but couldn?t decide whether to paint the H3 like you or leave it and paint the rest of the skid plate. I guess you decided for me? I?ll just have to be your opposite and leave the H3 alone and paint the rest black.
Thanks!
Old 12-30-2006, 10:58 PM
ictH3's Avatar
I used the left over paint on the skidplate like you suggested!
I'll let it dry for a day or 2 and then try and get some pics with it on my 3.
