Old 03-11-2008, 06:15 PM
Haydel-H3's Avatar
Haydel-H3 Haydel-H3 is offline
Haydel-H3 is on a distinguished road
Default Why buy 5 tires?
Hey tell me the truth will it screw up differential?
I drive 100 miles a day and go through tires like water, feels like it.
Only had one flat in 10 years of driving. Even driving off road.
If I buy 33" toyo's and have a 32" spare, would it be just like running on a low tire with the 32?
Is it worth Paying an extra $300
Explain the way the rear or front differential works on the H3.
Does the front and back have limited slip clutch plates?
I have the H3 non locker rear.
Old 03-11-2008, 06:48 PM
Default Re: Why buy 5 tires?
Its really a personal choice decision.
On the + side of 5 if you have a tire failure you just change it and away you go.
The -side of the 5 is the TPM's need reset when you introduce the 5th wheel.
+side of 4 is the money savings
-is when you mix in the smaller tire you must run slower or risk damage..
Old 03-11-2008, 07:10 PM
H3 Hummer 64 H3 Hummer 64 is offline
H3 Hummer 64 is off the scale
Why not buy 5 and rotate the spare in. That way all 5 will match and you'll get more miles out of that set.
Old 03-11-2008, 10:11 PM
wannabeH3's Avatar
i bought 5 35's and wish i bought 4. if i get a flat ill figure it out from there
(with insurance)
Old 03-12-2008, 03:04 AM
Dave92270's Avatar
the extra advantage of 5 over 4 is that the matching spare LOOKS BETTER
..actually much better. I used to have 4+1 (non-matching) in the past, and I hated it.. go for 5 matching, well worth
