12-30-2006, 04:42 PM
Interior lights
There are no illuminations from my tow/haul button or from the off button for the climate control. I can't remember if they ever did or if they have burned out. Anyone?
12-30-2006, 11:24 PM
Re: Interior lights
hmmm...i think mine light up...will check and let you know
2009 H2 Silver Ice LE
12-31-2006, 02:26 AM
Re: Interior lights
Adam, I just ran out there and looked. It's freakin cold!
Yes, both light up. When you push the tow/haul you also get an orange light on the RH SD of your speedo.
The Off button is also lit up.
12-31-2006, 06:44 PM
Re: Interior lights
Yes, they do indeed light up.
01-01-2007, 05:16 AM
Re: Interior lights
i concur....mine light up....
01-03-2007, 03:14 PM
Re: Interior lights
Hmmmmm.
How the hell do I fix those?
01-03-2007, 05:01 PM
Re: Interior lights
Hmmmmm.
replace the switches.
01-03-2007, 05:03 PM
Re: Interior lights
Hmmmmm.
dim all the rest of the interior lights so you don't notice
01-03-2007, 06:27 PM
Re: Interior lights
Done.
01-03-2007, 10:56 PM
Re: Interior lights
They could be bulbs or LEDs, they are designed not to be replaced; however, they can be. If you are good with a soldering iron and not worried about tearing the components apart.
I replaced all the component bulbs (radio, HVAC, I/P computer) and all switch bulbs on my Vette with Blue LEDs. Easily to disassemble the components and access the bulbs. Very hard to install LEDs in place of bulbs.
01-08-2007, 05:58 AM
Re: Interior lights
Adam,
The lights on the climate control unit are led's soldered onto a board inside the unit. So like f5fstop says, if you're good w/a soldering iron, go for it.
Not exactly sure about the tow/haul unit lites, my guess is there're probably the same.
FYI: the climate control unit is just over $400 & according to the Hummer parts guy, it has to be installed & programmed @ the dealer, if that helps w/ your decision to try and replace on your own.
01-08-2007, 04:18 PM
Re: Interior lights
Mmmmmmm. I like Paragon's solution.
"My car doesn't have any problems a louder radio won't fix" kind of solution.
01-08-2007, 05:26 PM
Re: Interior lights
Hey a$$hole, in my minutes, you'll have a PM.
