Old 01-11-2007, 05:36 AM
BACKNBLACK's Avatar
BACKNBLACK BACKNBLACK is offline
BACKNBLACK is off the scale
Default TORSION BAR PICTURES
Since no one that I know of has posted pics of the actual torsion bar Job getting done I figured it would be a nice post to have.
TBAR INSTRUCTIONS.
The front bar adjustments are located roughly under the divider between the front and rear doors--it is a bolt that is 1 1/16th inch. Measure from ground to bottom of fender BEFORE turning, then jack it up, turn CLOCKWISE the number of turns you want, then set down--remeasure.
***NOTE*** YOU MUST THEN GET IT ALIGNED.
I would use at leas a 21" 3 Ton Jack a bit overkill on the tonage but you need the height. Also no standard socket set has the 1 1/16 Socket so go to Sears and spend $10.69 on the socket. I would buy the DEEP socket as well for you will need the leverage. Make sure you have a breaker bar handy, the first two turns are pretty easy but the last 1/2 a turn is a bear. Make sure you have the truck tires off the ground in the front during the TBAr nut turn or it is next to impossible to turn the bolt.
This was a very easy Job. We did three trucks in less than 1 hour. The funny thing is in each truck the passenger side was nearly 1 inch lower (Stock Height) SO much for Hummer Engineering ;-) But than again thats what makes them Hummers..... Good Luck :0
JACK LOCATION
TBAR BOLT LOCATION
TBAR BOLT
Make sure you mark the bolts with a sharpie and turn CLOCKWISE.
The 35's 315/75 R 16 BFG Mudd Terrain. I am trading in my 33" Toyo Open Country M/T's :-(
CURRENT HUMMER:
Number# 11 2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
Old 01-12-2007, 02:43 AM
garnerbiker's Avatar
garnerbiker garnerbiker is offline
garnerbiker is off the scale
Default Re: TORSION BAR PICTURES
Thanks for the pics brutha. Nice stroler, hook that thing up with some 12 inch AT's.
[O][][][][][][][][O]
Old 01-12-2007, 03:06 AM
Excellent FAQ! May we add to the one we are building for the site?
Old 01-12-2007, 03:12 AM
BACKNBLACK's Avatar
Yes you may add it and thanks.
-Peter
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
BACKNBLACK's Avatar
I was thinkin more like 18's with spinners :-)
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
Old 01-13-2007, 02:11 AM
SDH3 SDH3 is offline
SDH3 is off the scale
Appreciate the pics!
Old 01-16-2007, 07:58 PM
aetherH3 aetherH3 is offline
aetherH3 is off the scale
Can I ask why you're switching from Toyo's to BFG's?
Old 01-16-2007, 10:05 PM
BACKNBLACK's Avatar
The Cost and I feel a little better ride. I paid $800 for BFG M/T Installed. The BFG 35's" are nearly $300 cheaper and at least just as good of tire than the TOYOS. I have had the BFG M/T'S on all 3 of my H2'S and had great success off-road. I really like the TOYO'S look better but for $300 bucks I'll take the BFG'S.
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
Old 01-17-2007, 01:58 AM
cool, i was just curious as i LOVE BFG's but i'm now in an area where we get a lot of snow and ice and the lack of siping on the BFGs is a concern for me. The Toyo's are more expensive, but in the end I would rather pay a little more for the better ice traction which probably isn't an issue for you. post pics when you get them on
Old 01-17-2007, 02:52 AM
Was that 800.00 for 5 of them? If so, killer deal!
I hope you have 5 that are the same size.
Old 01-17-2007, 01:41 PM
BACKNBLACK's Avatar
All 5 for $970. $800 was for the set of 4. Yes I have all the same size tire, even the spare
CURRENT HUMMER:
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
