Old 01-04-2007, 02:46 AM
TEhler TEhler is offline
TEhler is on a distinguished road
Default Wheels and offset
Hi guys
looking at some wheel on ebay 20 x 10 5inch backspace -12mm offset any one know if this offset will be a problem? and would you put a 38 14.50 on a 10 inch wheel?
Tim
http://cgi.ebay.com/ebaymotors/WELD-...QQcmdZViewItem
Old 01-04-2007, 03:22 AM
Default Re: Wheels and offset
Originally Posted by TEhler
Hi guys
Tim
http://cgi.ebay.com/ebaymotors/WELD-STYLE-FORGED-ALUMINUM-WHEELS-CHEVY-H2_W0QQitemZ270075721221QQihZ017QQcategoryZ43960QQ ssPageNameZWDVWQQrdZ1QQcmdZViewItem
If your truck is lifted, you should be fine with that tire size. I had a set of 18" rims with those specs and 35's and they fit fine. WIthout the lift 37 12.50 is the largest you can go without major rubbing.
Old 01-04-2007, 03:27 AM
Not lifted yet going to when i get the wheels. was worred about the -12mm offset think im going with the 6 inch fabtech. just trying to find out how much wider my front track will be. sent an e mail to them waiting to hear back
Tim
Old 02-03-2007, 05:52 AM
thaidoggs thaidoggs is offline
thaidoggs is on a distinguished road
Check out www.americanracing.com under the tech tab you will find a wheel offset calculator which will tell you exactly how much difference you will get by changing either rim size or offset.
