Old 02-06-2007, 09:47 AM
Default Where does the 12v red wire from the hitch go into the engine compartment?
I am trying to trace the 12-volt red wire from the trailer hitch to see where it comes into the engine compartment. It is suppose to come out on the driver's side where most of the cable looms are between the master cylinder and battery.
Can you refer me to the page in the Helm manual or a happy snap that might show it?
Old 02-08-2007, 05:21 AM
pdsq99f4 pdsq99f4 is offline
Default Re: Where does the 12v red wire from the hitch go into the engine compartment?
Behind the battery there are 3 connectors right by eachother. The one you want is the larger one with 16cavities. From there it runs into the fuse block to fuse 84.
Hope this helps.
Pete
Old 02-08-2007, 07:00 AM
Pete,
Where have you been all my life ???
Old 02-08-2007, 11:01 PM
Originally Posted by HummBebe
Pete,
I notice I have been relegated to oblivion again.
BUT
I still pledge my loyality...
RYD
Old 02-09-2007, 06:28 AM
Sorry RYD....It's Black History month, so Sewie is getting top billing until March 1.....
Old 02-09-2007, 11:04 PM
Originally Posted by pdsq99f4
Behind the battery there are 3 connectors right by each other. The one you want is the larger one with 16cavities. From there it runs into the fuse block to fuse 84.
Hope this helps.
Pete
I am assuming it is this wire loom. There appears to be at least two reds.
Old 02-10-2007, 12:37 AM
It's that large red wire in cavity 8. The smaller wire is actually orange. You can always use a cheap test light to see if it always has power on it to be sure it's the right wire.
Old 02-10-2007, 12:55 AM
Thank you for your help.
