Old 04-06-2007, 05:31 PM
BigPoppa1411's Avatar
Default gobi rack
I have a quick question. I just had the dealer install the H3 off road lights for the roof and was wondering, will I still be able to install a Gobi Roof Rack?
I am looking at getting the stealth model, but am worried that it wont fit with the off road lights? Can anyone help?
Old 04-06-2007, 09:11 PM
lotus4s's Avatar
lotus4s lotus4s is offline
Default Re: gobi rack
It will work with the rack no problem. I'm not sure about the wind deflector though. With my stealth rack it's about 4 inches from the front edge of the wind deflector to the top edge of the windshield glass if that helps.
Old 04-06-2007, 10:46 PM
blindzebra's Avatar
get rid of the factory up tops man. I have them too and I wish I would have gotten the markers and got some nice bright ones on a gobi. Don't get me wrong they do add a lot of lumens at night, but not nearly as much as good aftermarket ones.
Old 04-06-2007, 10:52 PM
well i was going to add the remote controlled spots i had seen from some previous threads. they are pretty cool and were on sale for 175. ea
thought i would mount them on my front guard since its big enough.
Old 04-06-2007, 10:54 PM
yeah... see thats what im worried about. how about your onstar antenna? did that pose any problems with the install?
Old 04-06-2007, 11:12 PM
WHen you order the tack you MUST SPECIFY that you have the HUMMER lights up there and if you have a sunroof or not as well. Than your good to go.
Old 04-07-2007, 07:53 AM
lotus4s's Avatar
No problem with the install but the wind deflector does block my XM satellite signal sometimes when going south. The wind noise is pretty bad without the deflector so I live with it as I didn't feel like relocating the antenna.
Thanks Tim for the definitive answer....
Old 04-07-2007, 05:12 PM
Also, if you guys/ gals do have the XM interuption, it's an easy fix. All you need is a Sirius antena to be mounted either on top of the rack or all the way in the back. It's about the diameter of a golfball but is flat. It's very easy to integrate. I don;t have a writeup on this or anything, but you can always PM me your info and I can go through it with you. GOBI has the kits or can tell you exactly what you need and I how to do it as well.
