Old 04-30-2007, 07:40 PM
Default cleaning a k&n air filter
how long should i let it dry for?? will overnight be good enough?? like 10 hours, it says dont use any other means to dry it or could damage the element, any ideas to "quicken" this process
Old 04-30-2007, 08:07 PM
MDimitri's Avatar
MDimitri MDimitri is offline
Default Re: cleaning a k&n air filter
Usually 24 hrs in door's is good, this why I bought two of the filters so that i wouldn't need to worry about this. Did you recharge them?
Old 04-30-2007, 10:01 PM
nmu98 nmu98 is offline
nmu98 is on a distinguished road
Something to read while your K&N dries.....
http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm
Old 04-30-2007, 11:24 PM
working Hummer's Avatar
Hell I clean it, shake it and set it in sun for 10 minutes and respray it.
Old 05-01-2007, 01:08 AM
HMMM, DAS INERESIN
Old 05-01-2007, 03:05 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Put it over the heat vent in your house or garage
Old 05-01-2007, 05:22 AM
MDimitri's Avatar
That stupid test is based on this filter being used as an example:
K&N 33-2135
H2's don't use that type of filter, they use the RP-5103:
Big difference!!
Old 05-01-2007, 12:50 PM
K&N 33-2135
Big difference!!
If K&N will let the first filter you posted go into production and be used on a diesel, what makes you think that the second filter you posted could, or would be so much better.
Old 05-01-2007, 03:33 PM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
Actually the test results are valid because the AC Delco A1618C is the exact same size as the K&N 33-2135.
Just because the H2 uses a larger filter doesn't mean you can ignore the test results, the pass-thru is still valid regardless of the media surface area, and other test values will follow a linear relationship based on filter size.
The stock paper filter design wins hands down in all aspects against any gauze and oil filter.
K&N air filters do a poor job filtering, and poor filters = shorter engine life.
