Old 05-23-2006, 07:30 PM
Klint's Avatar
Klint Klint is offline
Default Monsoon Subwoofer upgrade
I got the Monsoon 7 speaker upgrade it has a subwoofer I am guessing in the back. I want to upgrade to a 12? or a 15? subwoofer. Can I replace the Stock subwoofer by unplugging it and plugging in a 12 or a 15? does anyone know how much output the stock 6 Disk CD player has? I am pretty much clueless on how to do this so any information would help!!!
Klint T.
2007 Black Lux, Blinged out
Old 05-23-2006, 08:23 PM
Default Re: Monsoon Subwoofer upgrade
If you want to go with a different sub you are going to have to replace the factory sub amp. This amp is separate from the head unit and is back by the sub I believe. I would go with a 10" or pair of them before I would go with a 12" let alone a 15". Are you looking for a huge jump in the low end or just a little improvement? You will get far better sound quality with a pair of 10"s. If you just looking to improve it without making it sound like it should be running on 22s and lowered, go with a pair of 8"s or a 10" in the rear gate. Just my two cents
Old 05-23-2006, 08:37 PM
Klint's Avatar
hey,
has anyone done this yet? I justwant improve the sound alittle... how do I get to the sub?
Klint T.
Old 05-23-2006, 08:46 PM
You will have to pull the whole DS rear panel off to get to it. You can download a zip file with pics of BParker's sub install to give you some ideas. Just to warn you though, the file is 16 or 17 meg.
Old 05-24-2006, 01:48 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Originally Posted by Klint
...I want to upgrade to a 12? or a 15? subwoofer...
DAMN! That's a big subwoofer!
Old 05-24-2006, 02:51 AM
Klint's Avatar
Now I am going to take a look and see if how hard this is going to be and how big I can put in there without having to CUT
Klint T.
Old 05-30-2006, 05:12 AM
Klint's Avatar
How do I get that side pan. off? I pulled on it but I dont' want to break it.
Klint T.
Old 10-21-2006, 11:56 PM
Klint's Avatar
anyone?
Klint T.
Old 10-22-2006, 04:01 AM
marin8703's Avatar
PM me you email adress and ill send you the instruction on how to take the rear panel off, where the sub/amp are.
marin
Old 05-18-2007, 03:28 AM
Mr_Pat's Avatar
Mr_Pat Mr_Pat is offline
Mr_Pat is an unknown quantity at this point
Did anyone ever find out what the bigest size sub I can fit back there is. I dont want to cut up the case.
Old 05-18-2007, 09:52 AM
Idaho-Hummer's Avatar
Idaho-Hummer is off the scale
yeah, its about that size that fits in the sub enclosure.
Old 05-18-2007, 04:58 PM
H3slate's Avatar
H3slate H3slate is offline
You should check this thread out about a new sub enclosure made by JL audio. It fits in the space that the monsoon sub and amp took up in the rear panel. You would have to find a place for a new amp, but very clean install.
http://www.elcovaforums.com/forums/s...ad.php?t=25999
