Old 12-04-2003, 09:13 PM
H2Dude H2Dude is offline
H2Dude is off the scale
Ok, Im right in the middle of my XM radio installation and im down to hooking up the 2 yellow power leads (1 from the tuner and one from the adapter)? Call me dumb but where can I hook those wires up so they get constant juice. Any suggestions would be appreciated. I dont want to burn down my Hummer.
Old 12-04-2003, 09:17 PM
TouchdownTN TouchdownTN is offline
TouchdownTN is off the scale
Don't know anything about electrical matters but in planning my system I'm planning on tapping into Cig Lighter leads. Don't know if it is safe or even possible though I was looking for suggestions.
03 Black Adventure with all Lux Options,Brush Guard Lights, and Sylvania Silverstars. Go Vols!!!
Old 12-04-2003, 09:19 PM
cmb31078 cmb31078 is offline
cmb31078 is off the scale
I hooked mine up to the cig lighter that I do not use. The one behind the shifter. It works fine and I have two phone chargers plugged into the other two.
Craig
04 Pewter H2- Lux,nav, air suspension
Craig
Old 12-04-2003, 09:34 PM
Thanks guys. Are those hot all of the time?
Old 12-04-2003, 09:50 PM
Ok, im using the lighter hot (red) line. can I use the lighter hot for the ground or do I have to find some metal. As you can see Im a wuss when it comes to electricity.
Old 12-04-2003, 10:22 PM
Patriot Patriot is offline
Patriot is off the scale
Dude,
All you had to do was PM me a number to reach you at and I would have explained everything in detail.
Did you get my antenna message??
Old 12-04-2003, 10:30 PM
Patriot,
I did get the antenna message. I attached the yellow hot leads to the orange on the cig liter. Can I hook that ground to the black ground on the cig liter?.
Old 12-04-2003, 10:32 PM
Patriot,,,
Im trying to do the PM but I keep screwing it up
Old 12-04-2003, 10:37 PM
I used the cig lighter ground and power (both).
I get a small amount of hiss (alternator) that you can hear only during dead air or in between stations.
If you do put it there and have a prablem, you can always run a seperate ground wire to a more preferred location.
Old 12-05-2003, 02:02 AM
Thanks all,
I got the XM going and it sounds great. I cant seem to get the display to work though. I ll be calling soundgate in the morning.
Old 12-29-2003, 09:37 PM
Where is a good place to ground the PIOGM1 using Cig. Lighter for 12V lead
Old 12-29-2003, 10:01 PM
Touch,
I used both the "positive/juice" and "negative/ground" cig lighter wires.
Old 12-30-2003, 01:22 AM
Thanks for the info. I've got my I-pod in hand. PIOGM1V2 on its way and I am ready to install this thing and try it for myself. Any hints or suggestions. Looking for info. you wish you would've known before starting the install. Thanks,
Old 12-30-2003, 10:57 AM
Touch,
Here is a thread with a little info. It also hasa link inside the thread for removing the center console. If you do a search, there are a few others you may get some other tid-bits from. It went very easy.
http://elcova.com/groupee/forums?q=Y&a=tpc&s=2826088551&f=6706011751&m=23660 48005&p=1
