Old 07-17-2007, 01:37 AM
scottyboy scottyboy is offline
scottyboy is on a distinguished road
Default Price to fix leaking air suspension?
Anyone have a rough price on this? I'm assuming that's my problem, after about 2 or 3 hrs the back drops 6 to 8 inches and one side is lower than the other, is one bag bad or both? Thanks.
Old 07-17-2007, 03:25 AM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
Default Re: Price to fix leaking air suspension?
There are a couple schools of thought on the bags- you can buy them and do the install yourself, or have the dealer do them and in the process set the "Z" height adjustment and do the code update for the sensors & compressor cycle.
I would rather have done them myself, but had the dealer do it since I needed the code update anyway.
If you have an 03 there is an update so the compressor won't cycle so much, ask them to also update the "auto volume" on the radio at the same time. Early versions of the code didn't time the signal to the sub at the right time so the auto volume button has to be cycled each time after the system is on, unless you do the update.
Old 07-17-2007, 03:26 AM
Sorry- forgot the meat of the question, IIRC the price on mine for everything was around $550.00 which was a relief since I don't have a warranty and feared the compressor was involved which is big bucks.
Old 07-17-2007, 03:32 PM
who does it depends on whether it is under warranty or not....plus when the dealer installs stuff you get a part and labor warranty as well....
