Old 08-10-2007, 10:18 PM
craig41071's Avatar
craig41071 craig41071 is offline
craig41071 is on a distinguished road
Default H3 gas pedal knocking
I have 8000 miles on my 07 I have been feeling more than hearing a knock in my gas pedal/steering column fell it both places it has really gotten bad today I called dealer and they can't fit me in till 4 days from now any suggestions on what it might be? I don't want to get there and they say they can't feel it because I know it is there
Old 08-10-2007, 10:28 PM
scotty1007 scotty1007 is offline
scotty1007 is on a distinguished road
Default Re: H3 gas pedal knocking
Check out other threads Seems to be an intermediate steering shaft problem
it is heat related apparently alot of 07's are affected by this
Old 08-10-2007, 10:39 PM
bject: Clunk Or Knock Noise Heard And Felt Through The Steering Wheel Or Brake And Accelerator Pedals - keywords intermediate rattle shaft #PIT4448 - (06/27/2007)
Models: 2007 Hummer H3
Condition/Concern:
A clunk or knock noise is heard and felt through the steering wheel or brake and accelerator pedals, the cause is a slip/stick condition in the lower steering shaft. This is a temperature sensitive issue and usually requires the vehicle to have been driven for a period of time to increase under hood temperatures
Recommendation/Instructions:
Replace the lower steering shaft part no. 25776339. There is a high probability that replacing the shaft will correct the condition as there are only a small percentage of parts that exhibit this condition. This PI will be updated when a new part number becomes available.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Mine has this problem to just bought three weeks ago Seems to be widespread
Old 08-11-2007, 01:14 AM
ChiHummer3's Avatar
Had my H3 in the shop for the steering column noise/movement (among other things) a few weeks ago. They couldn't duplicate the problem. Go figure.
They did say they tightened the body mounts....and thought that might fix it. It didn't - so if they tell you that's what their fix is.....it won't work.
I'm not sure how they couldn't duplicate it cause it pretty dam obvious to me.
Old 08-11-2007, 04:13 AM
BigPoppa1411's Avatar
started noticing this about a week ago. gonna get it checked next week.
Old 08-11-2007, 02:38 PM
craig41071's Avatar
Glad I am not the only one atleast I can tell the dealer what it may be. I hate having a problem and having service tech drive it and tell me that they don't hear or feel anything. It does seem to be tempurture sensitive because it was over 104 degrees here Friday and I thought the front end was going to fall out the truck and was afraid to drive it over the weekend but got in it this morning and had no problems till I got in to town and then it started a little bit
I have 8,000 miles on it and the only problems so far ae:
1.this knocking, bumping feel
2.driver door clicking weird dealer said they would have to put new hinge actuator
3.map pocket torn from stitching I have never used it but I guess maybe folding rear seat down tore it?
Thanks!!
Old 08-11-2007, 03:35 PM
fourfourto's Avatar
Whats this map pocket you speak of ?
Old 08-11-2007, 06:15 PM
Spuds's Avatar
Spuds Spuds is offline
Location: Houston (The Heights)Texas <'))))>?{ . N 29.47.89 W 95.25.71
Spuds is on a distinguished road
Condition/Concern:
Mine is doing it as well.
Thanks for the heads up on what it might be.
Gone but not forgotten:
'78 CJ-7 4-sp w/granny
'81 Subaru 4x4 GL Wagon
'87 Jeep Grand Wagoneer
'91 Jeep Grand Wagoneer
'04 VW Touareg VR-6
'07 Hummer H3 I-5 Lux/Offroad
Current:
'03 Ford Ranger Super Cab FX4
'09 Hummer H3 Alpha Offroad
Handle every situation like the dog !!
If you can't Eat it or Screw it; Piss on it and Walk Away.
Old 08-11-2007, 10:08 PM
6pack 6pack is offline
6pack is an unknown quantity at this point
I am having the same problem and have been told it is the steering shaft also. Went to the dealer two weeks ago and mentioned that's what I thought it was. They said no way. They came back an hour later and said it was the steering shaft. :/ They need to order the part and I haven't heard back from them yet. I will call them Monday and see what's up. But it is warrenty, so no charge to fix it... other then the hour it takes me to get to the closest dealer. I loose a half day just for a stinkin oil change.
Old 08-11-2007, 11:37 PM
YANKEES31's Avatar
YANKEES31 YANKEES31 is offline
YANKEES31 is on a distinguished road
I think I may have the same issue. When I brake a and turn or accelerate and turn I hear a sort of clicking sound. It almost sounds as if something is real tight and aabout to snap.
Is this what everyone else is experiencing?
Jared
2007 H3X-MOTO METAL 951'S-TOYO 33x12.5 MT'S-MAGNAFLOW EXHAUST-TRUXX LEVELING KIT-PIONEER AVIC Z2-CARBON FIBER INTERIOR TRIM-REAL WHEELS HOOD DECK GRILL-NUMERIOUS OTHER CHROME ACCENTS
http://jaredneumann.tripod.com/index.html
Old 08-12-2007, 02:31 PM
craig41071's Avatar
I emailed my sales person and forwarded the link to the forum she admitted it was a huge problem and said they have the new columns and installed several just last week. She wants me to call her monday morning so she can make sure they have one with my name on it so they can put it on the same day so I won't have to make two trips
Old 08-12-2007, 04:56 PM
That's not really what mine does. Mine is whenever you hit any little bump, there is a knocking feeling through the pedals and steering wheel. It's like something is loose and rattling around.
Old 08-13-2007, 02:58 PM
craig41071's Avatar
that is what mine is doing I will let you know if the column fixes it but the dealer said it would it was an easy fix and they have done several. The steering column is VIN specific I guess they know which ones have the faulty ones
Old 08-13-2007, 03:12 PM
BST1YET's Avatar
BST1YET BST1YET is offline
BST1YET is on a distinguished road
I'm having the same problem and I only have 1100 miles on mine. Called the dealer and before I could finish explaining what the problem was they new what the issue was. They've ordered in the new part for me and I should be getting it replaced later this week. I will update everyone afterwards
07 H3 Base, auto, Black w/ black interior, chrome door handles and mirrors, leveled on rollin on Goodyear MTR's
Old 08-13-2007, 03:20 PM
craig41071's Avatar
here is the email my dealer sent back to me:
Yes, I know exactly what problem you are talking about?.good news is?it is not a safety issue. When they modified the steering shaft for the 2007 Hummer H3 (because they increased the distance between the brake pedal and the gas pedal) it bumps the bottom of the Hummer.
Great news is?.we received the new steering shafts and we are installing them as fast as we can.
Four Hummers were fixed on Friday and we are making appointments left and right for the ones that need to be fixed
Old 08-13-2007, 03:32 PM
ChiHummer3's Avatar
So this "fix" is directed at the 2007 H3 only then??
Mine's an '06....and is doing the same thing.
Old 08-13-2007, 03:34 PM
craig41071's Avatar
maybe some of the late 06's got the same shaft???
Old 08-13-2007, 03:37 PM
ChiHummer3's Avatar
Guess I'll talk to the dealership and tell them what I've found out here and see what they have to say. It's under warranty - so it's their problem to find out what's wrong. At least I'll be able to point them in a direction since they couldn't reproduce the sound/feeling the last time the truck was in for service.
If you get any other info please post it! Thanks!
Old 08-13-2007, 10:55 PM
3Hummer's Avatar
3Hummer 3Hummer is offline
I had this problem as well, we took it in and they said there was nothing to do, when i go for my next oil change im going to mention this and see whtat they have to say. It doesnt bother me all to much, but if i can get it fixed no charge since its under warranty mineaswell get it fixed
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 08-14-2007, 02:59 PM
preslb76 preslb76 is offline
preslb76 is on a distinguished road
I am having this problem too. Less that 3000 miles on it. Has anyone had a repair completed and did this fix the problem??
