Old 09-27-2007, 04:57 AM
The Ledge The Ledge is offline
The Ledge is off the scale
Default Factory Roof Side Rail/Tracks?
Do all H2 base models come with the factory roof side rail/track assembled in place? Meaning if a customer wanted roof rack cross rails as an added option it is just a matter of the dealer adding the luggage cross rails to an already factory assembled track?...or, are the rail/tracks assembled to the roof on order with the cross rails?
Old 09-27-2007, 06:05 AM
Default Re: Factory Roof Side Rail/Tracks?
ALL will have the rails that run from front to rear.
Yes, all that owner will have to do is add the crossrails that run from pssd to drsd.
Old 09-27-2007, 11:45 AM
Thanks for that info!
Old 09-27-2007, 01:26 PM
3Hummer's Avatar
3Hummer 3Hummer is offline
i still never understood what you can use the other types of rails for, the ones that run parralel to to the roof it just makes no sense, what can you put on them?
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 09-27-2007, 11:19 PM
Alan06SUT's Avatar
Old 09-28-2007, 05:49 AM
tower's Avatar
tower tower is offline
Don't they all run parallel to the roof? If not, they stick straight up. To which ones are you refering?
