Old 10-07-2004, 02:23 PM
I've been thinking about upgrading my shocks. The stock ones are just not doing it for me. They're too mushy under hard braking.
I've been thinking about going with some Edelbrock Xtreme Travel Reservoir Shocks.
I've seen them on an H2 in the showroom, but haven't had a chance to ask any one for an opinion.
Old 10-07-2004, 02:24 PM
Rear shock.
Old 10-07-2004, 02:46 PM
Dan Dan is offline
Use the Search ya lazy BASTID!
Old 10-07-2004, 03:03 PM
Check with brklyn, he has them. I remember seeing them at Paragon.
Old 10-07-2004, 03:35 PM
Unless you just want the look of the extra reservoir, I would go with their regular IAS shocks. I have used those on several different vehicles and I really like them.
I have been told that the xtreme travel shocks won't offer any better performance that their standard IAS for the H2. If you don't have a lift kit and since we don't have great articulation, the extra travel and extra fluid is not needed.
Old 10-07-2004, 04:19 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Dan:
Use the Search ya lazy BASTID! <HR></BLOCKQUOTE>
I did, you knucklehead.
I found the thread with Brklyn, but I wanted to see if anyone else had installed them but hadn't written anything up yet. I was trying to coax some of the newbies or lurkers into participating.
Old 10-07-2004, 11:45 PM
HUMMERS HUMMERS is offline
HUMMERS is off the scale
I paid $280 for all 4 Bilsteins instead. It’s the best upgrade for money.
Old 10-08-2004, 12:16 AM
Patriot Patriot is offline
Patriot is off the scale
I was thinking of upgrading too...
What about the Rancho's???
Those Bilsteins sound good for the money...how's the ride??? Where did you get them??
Old 10-08-2004, 02:08 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Patriot:
Those Bilsteins sound good for the money...how's the ride??? Where did you get them?? <HR></BLOCKQUOTE>
The ride is smoother and better handling compare to OEM.
I got them from here.shox.com
Old 10-08-2004, 10:00 AM
Hummers,
When you say smoother you don't mean softer do you? I'm looking to firm up the ride a bit.
I have 37's on and they seem to be giving the OEM shocks a run for their money.
I want a firm ride with little flex going into corners.
Old 10-08-2004, 01:30 PM
AZhummer AZhummer is offline
AZhummer is off the scale
HI Guys, I have them on my rig. 37 MTA's as well. They work great. Like having an extra sway bar on road and very compliant off road.
I have had the shocks on for 32k miles and they are still as new. Great investment in upgrading to any good aftermarket shock.
03 H2
Old 10-08-2004, 01:41 PM
How hard is replacing the shocks on the H2??
Is jacking-up/lifting the vehicle necessary or can it be done in the driveway?
Old 10-08-2004, 01:42 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by AZhummer:
I have had the shocks on for 32k miles and they are still as new. Great investment in upgrading to any good aftermarket shock. <HR></BLOCKQUOTE>
Which model?? The Bilsteins, Rancho's, or Edelbrocks???
Old 10-08-2004, 02:15 PM
Edlebrocks, yes jacking up the frame is the easiest as the shocks are fully extended when you get them. The body will lift high enough so the install is easy.
03 H2
Old 10-08-2004, 02:44 PM
Hummers,
I want a firm ride with little flex going into corners. <HR></BLOCKQUOTE>
The rising rate self-adjusting design of the Bilstein shock provides softer and firmer depend on the road surface. I feel better ride comfort on rough surface and stability on highway. I was thinking of upgrading sway bar but didn’t want to compromise the off-road capability of the truck.
Old 10-08-2004, 02:57 PM
I tried the IAS on my Tahoe. They were great on the road, but awful offroad. Way too much rebound over uneven surfaces.
Old 10-08-2004, 04:31 PM
I tried the IAS on my Tahoe. They were great on the road, but awful offroad. Way too much rebound over uneven surfaces. <HR></BLOCKQUOTE>I don't think there is much difference between the extreme travels and the regular IAS. I think they both use the same technology except the pistons on the extreme travel are thicker and, of course, you have the extra oil.
I've had them on F250, Expedition and a Jeep and thought they tamed everything well and didn't allow for sway on the highway. Personally, I think they stop the rebound extremely well compared to anything else I've had, even Rancho 9000s.
Old 10-08-2004, 07:58 PM
kdio kdio is offline
kdio is off the scale
I put the Rancho RS9000X on my H2. Way better performance both on and off road. I like how you can adjust the shock to 9 different settings. While on the road I set them at 4 and when off road adjust them to 7.
