Old 12-11-2007, 10:00 AM
Ernie Italy is off the scale
Default REMOVE WEIGHT
My H1 is 3480 kgs that are 7733 lbs with ...
two full fuel tank
Heavy duty brush guard
Winch
More mud...
The weight is too high and need to reduce...
Suggestion ??
Ernesto Italia
Old 12-11-2007, 10:09 PM
ssgharkness020147's Avatar
Default Re: REMOVE WEIGHT
Why do you need to remove weight? How much do you need to remove? First off I would pull the brushguard and the winch, it would suck to see them go, but they are accessories.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 12-12-2007, 03:00 AM
phazer42 phazer42 is offline
phazer42 is on a distinguished road
Winch, ~120lbs
Under caridge protection ~ 150lbs
Brush guard ~50lbs (depending on what one)
rear bumper (if state allows) ~120lbs
fuel tank ~40lbs empty plus ~60lbs for fuel
Interior ~200lbs
get a Soft Top ~100lbs
run flats ~40/wheel
bottom line is, its a heavy truck.... without re-engineering the vehicle you are stuck with it.... if you don't like the weight why not get a Jeep?
Old 12-12-2007, 05:37 AM
tower's Avatar
tower tower is offline
Just put a lot of helium baloons in the cabin. Yellow works best (lightest).
