Old 11-30-2007, 02:05 AM
JohPol JohPol is offline
JohPol is off the scale
Default Edelbrock Shock Install
Would like some input from anyone that has installed Edelbrock shocks.
The rear set went on no problem.
The fronts came up a little short. They appear to be about 1 inch shorter than the stocks. I do have the TB cranked up about 3 turns and plan on installing a set of reindexed keys. When I went to put the front shocks on they are coming up short.
Any help insight would be appreciated.
Old 12-11-2007, 05:22 AM
Default Re: Edelbrock Shock Install
Cranking the TB's pushes the lower A-arm away from the frame, creating more distance between the upper and lower mounts. You really should get longer shocks, like the Cognito/Bilsteins. There are also extensions out there but I'm not a fan of them. You can use the Edelbrocks (just extend the shocks when mounting them) but you may end up topping them out if you go offroad.
