Old 12-24-2007, 12:28 AM
jdrew's Avatar
jdrew jdrew is offline
jdrew is on a distinguished road
Default SMA light bar
Any difference between the SMA "rear light bar" and the "front light bar" physically?
I haven't been able though searching various sites any information to see if there is a difference...
I did notice that they have different part numbers (20032225 and 20032226)..
Evansville, IN
'05 H2 SUT Slate Blue LUX w/Nav, NightDriver
H.O.P.E. Member
Old 12-26-2007, 12:12 AM
jdrew's Avatar
Default Re: SMA light bar
can't believe nobody has seen either of them...
Evansville, IN
H.O.P.E. Member
Old 12-29-2007, 09:15 PM
bennersj bennersj is offline
bennersj is on a distinguished road
not sure of the difference but both are available on ebay right now.
Old 12-30-2007, 02:51 PM
OU812 OU812 is offline
OU812 is on a distinguished road
I have the front SMA light bar installed, and the rear waiting until it gets warmer. I am not at home so I cannot physically hold the bars up to each other, but they do appeared to be the same. However, the front I know came with the main wire components (e.g., relay, switch, etc.). It appears the wires from the front push into the relay of the front.
I wanted to install my rear ones closer to the end of the roof instead (as the instructions say) of in the roof rack channels.
How about you? Are you looking to do a rear set as front, doing both sets, or other?
Old 01-01-2008, 04:41 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
jdrew, just buy both and install them.
Happy new year to ya!
Mike
____________________________
Old 01-04-2008, 03:00 AM
H3 Hummer 64 H3 Hummer 64 is offline
H3 Hummer 64 is off the scale
I just won the front sma light bar off of ebay. Can any who has this tell me if there are any tips or tricks they discovered to help with the install? How hard was the install? Are you pleased with the performance of this light bar? thanks
To answer the question about the difference between the front and rear bar I might have an answer. I could be wrong though. If its like the plus one (xtc) light bar I believe the front bar uses driving lights while the rear uses fog.
