Old 10-01-2008, 08:03 PM
sammy1 sammy1 is offline
sammy1 is on a distinguished road
Default wires chewed by rodents
Squirrels, Chipmunks or mice have chewed wires in the engine compartment of my 2006 H3. I've already found and fixed four wires, but still have ABS, Traction control, Check engine, brake lights on, plus cruise isn't working. Where can I get a wiring diagram so I will have an idea where to look for additional chewed wires? The ones found so far, just happened to be visible. The only code thrown to my scanner is PO449 evap control system malfunction.
Thanks in advance for any suggestions..
Thanks in advance for any sugestions..
Old 10-01-2008, 10:13 PM
Default Re: wires chewed by rodents
HANG GARLIC BRAIDS in your engine compartment, NOW !!!
Old 10-02-2008, 11:45 PM
Thanks for the advice RubHer Yellow Ducky.. I'm also trying to convince my wife to pull guard duty with the .22 rifle anytime the vehicle is parked outside. No luck yet. Garlic, hummm.
By the way, I was able to find the wireing diagram,
Old 10-03-2008, 12:48 AM
give her bathroom breaks...
Old 10-03-2008, 04:08 AM
Bodyarmorguy Bodyarmorguy is offline
Bodyarmorguy is on a distinguished road
You in Tallhassee FL by any chance? A buddy of mine up there had squirells chew through the wiring of his Suburban..$1200 bucks in repairs.....
Old 10-18-2008, 08:33 PM
Michael1 Michael1 is offline
Location: Northwest of Los Angeles, just outside all the traffic
Michael1 is on a distinguished road
Isn't this covered by your insurance? I would install a new harness.
Michael
Old 10-18-2008, 11:58 PM
use braided stainless over the insulation !
Old 02-28-2010, 02:33 PM
I found the chewed wires at the rear of the vehicle by the EVAP cannister. There were two white wires a brown and orange wire. A white and brown went to the left rear speed sensor and the other white and the orange wire went to the EVAP cannister. Also, damage from rodents and animals is covered under the comprehensive coverage of most auto insurance policies.
Old 03-05-2010, 04:56 AM
cdmintmi's Avatar
cdmintmi cdmintmi is offline
cdmintmi is on a distinguished road
i was getting ready to tell you to check your speed censor wires. i wrapped a 6ft metal silt fence stake around my A arm a while back going to through a deep puddle at work. It pulled the wirring loose and I got the same errors.
Glad you found the problem. If you want to get back at the squirrles try a "Yankee Flipper". Show em whos boss and no clean up!!!!
http://www.drollyankees.com/products...e-flipper.html
