01-06-2008, 02:37 AM
Tiny hole in Catalytic converter
Was letting the 2006 H3 warm up, it was 5 degres, and I noticed exhaust coming from the middle of the H3.
I crawled under. There is a tiny hole in the middle of the catalytic converter.
It is NOT a rust hole. Looks like a 1/8th drill bit size.
I am assuming this is normal. Anybody else notice thge hole?
01-06-2008, 02:51 AM
Re: Tiny hole in Catalytic converter
I think someone drilled it, i've heard of this. do you have any  enemies?
2007 h3x
2006 GMC 2500HD DURAMAX
01-06-2008, 04:03 AM
can't tell, it never gets that cold here...
01-06-2008, 07:01 AM
Sure its not the muffler or the resonator as they both have drain holes for moisture. Cat should have no holes.
01-06-2008, 12:51 PM
 Mine drips condensation, sometimes blackish water during warm up thru hole in muffler/resonator...
01-06-2008, 03:57 PM
same here
01-08-2008, 03:18 PM
Normal, it is supposed to be there to drain the water. You're probably seeing the resonator and not the cat.
