Old 01-04-2006, 04:59 PM
I have the new spare ready to mount on the tire carrier. My only problem is getting it up there. It's a freaking monster and the wife can't help pick this thing up.
I was thinking about renting a crane, but that's a couple hundred bucks an hour with a minimum of three hours. I could also call an Over the Road tire company with a portable crane to help.
What about a local construction company? I could borrow a cherry picker or backhoe.
I have a neighbor with a Vette. I bet I could roll the tire down the street real fast, up his hood, to the roof and then wiggle it on the truck.
Thanks for your help. I really need this mounted soon.
BTW, I did think of using the P/U bed backed up to the H2, but not until the tire was out of the truck.
Old 01-04-2006, 05:02 PM
wait till i meet u and i will help
Old 01-04-2006, 05:16 PM
SoonerBoarder's Avatar
SoonerBoarder SoonerBoarder is offline
SoonerBoarder is off the scale
Rent a Cherry Picker. Or, you can get one at Sam's for around $150, usually.
Old 01-04-2006, 05:19 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MONSTERMATT:
wait till i meet u and i will help </div></BLOCKQUOTE>Sure, just drive right on past Tyson's, take 64 to VA Beach...
Old 01-04-2006, 05:33 PM
Dan Dan is offline
Old 01-04-2006, 05:49 PM
GLBLWARMR's Avatar
String a come-along up over a tree branch and winch the bastard up then back up to it and slide it on. That is what I did when I decided that it would be a good idea to take it off.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
Old 01-04-2006, 05:53 PM
Good suggestins, gang, but not quite there yet.
What if I bounce it off the deck, into the P/U, stand it up and back the SUT up to it? Just not sure about the bouncing part.
Oh, Oh... I could buy one of those inflatable kiddie toys, put the tire on it and inflate the toy. Yeah!!!!
Old 01-04-2006, 05:59 PM
Mr. I - Man's Avatar
Military press it up , Girlie Man!!!
Old 01-04-2006, 06:25 PM
rodster rodster is offline
rodster is off the scale
\'05 SUT
Old 01-04-2006, 06:55 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mr. I - Man:
Military press it up , Girlie Man!!! </div></BLOCKQUOTE>Suck it! Did I mention I have at least one cracked/broken rib from the girl tripping me down some stairs? And LAUGHING!?!?!?!
Maybe Rod has the answer.
Of course, I could build a ramp. Yes, build a ramp up to the truck and roll that sum-beatch up it...
Or even better, I could loop the DRTY Bumper Winch line over the brush guard, over the roof racks to the back of the truck and winch that sucka up...
Oh yeah, I'm getting all manly here. Where's the chainsaw?!?!
Old 01-04-2006, 07:02 PM
Dan Dan is offline
Pretend its a big, frosty cold Coors Light that you need to curl.
Here's what to do:
- Remove the tire carrier from the truck.
- Roll the spare into the garage.
- Place carrier in center of garage floor.
- Photograph the carrier.
- Put carrier on eBay.
Done!
Old 01-04-2006, 07:06 PM
H2Finally's Avatar
I actually had the same problem before.
My solution was to place one of those little giant folding ladder in its most extended (open) position next to the H2, then rolled/lifted the tire to the top of the ladder, balanced it on the top most step, climbed on the H2 roof, grab the tire, and tip it down gently onto the roof.
After 3x, I bought a rear tire carrier.
Can BLING Get You Home?
Old 01-04-2006, 07:07 PM
Are you still here?
I can't sell it until I have a viable alternative to carry it. It won't lie flat in the back like the little stockers.
Old 01-04-2006, 07:08 PM
After 3x, I bought a rear tire carrier. </div></BLOCKQUOTE>My tire weighs more.
Now go back to work H2F. I heard you're a bery, bery busy pewson.
Old 01-04-2006, 07:11 PM
ree's Avatar
ree ree is offline
Wuss. I know your spare is bigger than stock, but you should be able to heft it up there. Just make sure CP's not around with the video cam. I was glad I was inside my closed garage, alone when I mounted my spare. It might have been embarassing otherwise.
Or get one of these.
http://www.predatormotorsports.com/index.asp?PageAction=VIEWPROD&ProdID=5
Teaka might have it cheaper.
Or, along the lines of a winch, custom fab a rear winch bumper, rig a pully on a flip up arm above the carrier and lift it up that way.
'03 pewter base H2
Old 01-04-2006, 07:15 PM
ree's Avatar
ree ree is offline
Will a 60" hi-lift with the tire attachment get it high enough?
'03 pewter base H2
Old 01-04-2006, 07:22 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ree:
Will a 60" hi-lift with the tire attachment get it high enough? </div></BLOCKQUOTE>I'm listening, . Actually, I'm just going to toss it up there for a while, then figure something else out. Someone<span class="ev_code_WHITE">DRTY</span>told me they'd look into something.
Old 01-04-2006, 07:28 PM
ree's Avatar
ree ree is offline
I'm listening, . Actually, I'm just going to toss it up there for a while, then figure something else out. Someone<span class="ev_code_WHITE">DRTY</span>told me they'd look into something. </div></BLOCKQUOTE>
This thing: http://www.hi-lift.com/products/liftmate.htm
it looks like you could get it up to about 4feet with the lift. Probably too low and cumbersome to work well.
'03 pewter base H2
Old 01-04-2006, 08:10 PM
mstams
Probably too obvious -- but is there a hill nearby that you could roll it up and back up to?
