Old 01-07-2008, 05:11 AM
hummercam hummercam is offline
hummercam is on a distinguished road
Default LIGHT BAR WIRING
I'm building a roof rack with light bar for my H3 and wanted some advice on where to run the wiring. Down the windshield pillar and then through the fire wall? Can the plastic moulding on the pillar be easily removed? How? Thanks for the help!
Old 01-07-2008, 01:17 PM
Default Re: LIGHT BAR WIRING
use the search function...it is covered several times...
Old 01-08-2008, 06:00 PM
hummerpartsman's Avatar
hummerpartsman hummerpartsman is offline
hummerpartsman is on a distinguished road
YOUR H3 IS ALREADY WIRED FOR LIGHTS, DO A WEB SEARCH FOR THE WIRE DIAGRAM, i DID IT ON MY H3 BUT I DO NOT REMEMBER THE WIRES.
Old 01-10-2008, 07:33 PM
Its all in here from befor (search) just a couple of lessons learned...
- you should run the wire down the inside of the black plastic molding. Be sure to secure it so it wont slap around at high speeds later.
-When you drill thru the firewall make sure to seal it when you are done to prevents shorts and keep gases and noise from cabin.
-Use good quality switches and wire to avoid problems down the road.
Have Fun
Old 02-01-2008, 09:10 PM
Haydel-H3's Avatar
Haydel-H3 Haydel-H3 is offline
Haydel-H3 is on a distinguished road
If I could get someone to tell me how to attach pictures here I could show you what you need. You don't need to drill on anything, run your switch wires through the hoodlatch cable grommet. Push the cable from the engine side and it will pop out by the break area, run one wire at a time through the grommet from engine compartment through the grommet. Yes it is tough but it will go through and provide a water tight seal once you grab the cable and pull it and the grommet back through the fire wall. Note: I can e-mail you pictures if needed.
Old 02-01-2008, 09:23 PM
Haydel-H3's Avatar
Remove the fake air box (grab and pull up)
Use a stiff wire and run it from the top under the plastic and tape to the end and pull it up. Just did mine this past weekend works fine looks good.
Will send pictures, but can't figure out. Have all wiring and switch hookup to.
