Old 02-26-2008, 04:15 PM
scooch33 scooch33 is offline
scooch33 is on a distinguished road
Default Cognito's Blisten Front and Rear is there a Diff?
I bought Two From www.trailduty.com and after I have read Countless Post on this Subject I am now wondering if they sent me the rears instead of the fronts, or is there a Difference? The First Picture is a front install on another site. The Second is a Picture of the Shocks they sent me. The Boots are reversed. and there is a "R" written on bottom mount. Any help would be apprecited before I start the install. Thanks
Old 02-26-2008, 07:52 PM
nicos nicos is offline
nicos is on a distinguished road
Default Re: Cognito's Blisten Front and Rear is there a Diff?
they are fronts!
installed mine not too long ago and are exactly the same as yours!
Old 02-26-2008, 10:54 PM
BKNBLCK BKNBLCK is offline
BKNBLCK is on a distinguished road
I put the same front shocks on mine last week. Part number on the box was F4-BE5-C153-HO. The boot on yours is in the correct place.
Old 02-27-2008, 12:33 AM
I double checked the part # and went ahead and had them installed today.
Everything is great!!! Wow what a Diffrence.
thanks
Old 02-27-2008, 12:40 AM
Desert Dan's Avatar
So with the longer shock is there enough room under compression (bottoming) so the shock doesn't become the bumpstop?
What is the compressed length of the Cognitos compared to the stock shocks? If they don't compress to the same length of the stock ones then the shocks with get damaged for sure.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 02-27-2008, 02:16 AM
Just a slight difference. The rears use a barpin (top) and eye (bottom) mounts. It would be quite a trick to make those fit.
Looks like Cognito changed the shock they were using to make these. I can check the exact part # when I get home, but IIRC, the ones I got (in that pic BTW) were originally made for a Ford.
