Old 06-16-2007, 06:20 AM
tomp's Avatar
tomp tomp is offline
Default FS: SMA Trailing Arms
Here is a chance for you anti-blingers to pick up a good set of trailing arms for a good price! These SMA Trailing Arms are much beefier than stock. They were purchased new, but just like the rumors say, the poly bushings wear out fast. They are now used, I took them off and I had them fitted with brand new OEM rubber bushings! The install of the bushings was performed by True Tech Performance. They have not been used since new bushing's have been installed. However, this process messed up the chrome finish. Now they make a good set to have Line-X applied to them!
These are solid billet aluminum and were very pricey new ($450). Take advantage of this chance to pick up a real nice heavy duty set, have them sprayed with Line-X, and not have to worry about messing up the old shiney chrome finish that was once there
PM me if interested....
Old 06-17-2007, 07:06 PM
tomp's Avatar
Default Re: FS: SMA Trailing Arms
pic shows new OEM bushings installed and chrome peeling off as a result of this process. Granted I peeled off more of it myself in order to prep them for Line-X. Also pic appears to include my fingerprints
Old 06-17-2007, 07:12 PM
tomp's Avatar
The reason the chromed peel off is not due to installing these bushings, but because of the machining process that True Tech Performance did to modify them for the OEM bushings. I wanted to point this out in case someone wanted to powdercoat or perform some other type of refinishing other than Line-X where the bushings may have to be taken out to apply the finish.
Old 06-24-2007, 03:11 AM
tomp's Avatar
I still have these...
Old 06-26-2007, 03:09 PM
MattRoberts123 MattRoberts123 is offline
MattRoberts123 is on a distinguished road
I see some big chrome and little rubber in the background of that one pic... looks like my type of style.. lets see the whole pic!
Carless... riding the bus... Trying to decide on which 08 H2 to get
Old 06-27-2007, 09:39 PM
tomp's Avatar
Sorry Matt....I don't go there on the H2. That's my Harley
Old 06-27-2007, 09:40 PM
tomp's Avatar
Trailing arms are sold
Old 03-16-2008, 07:43 AM
8500lbs's Avatar
8500lbs 8500lbs is offline
8500lbs is on a distinguished road
I think i just bought these. lol!! if not then the chipping or chrome peel is identical to the ones I got coming, and they too have had the poly. changed out. i hope this is not a sign for failure or problems? third truck in less than a year!
B
