11-05-2007, 07:35 PM
SUBWOOFER ENCLOSURE
11-05-2007, 07:46 PM
Re: SUBWOOFER ENCLOSURE
I have NOT tried them. Based upon the e-bay photos and text, I would say that they look like crap, they are made of crap and my best guess would be that they will sound like... You guessed it. They don't say or show where they install so that you can use them "without giving up any room" (which I doubt). I would look for something more befitting the quality of your vehicle purchase.
11-05-2007, 08:11 PM
I amm with tower. I would buy something else. I would check out a JL Audio combo/spec boxes. I don't really know what they refer to them as, but they are made custom for the h2, house the woofer, amp etc. Everthing is incuded. I have see some that fit under the rear seat. This way you air space, woofer and power range are all perfectly matched up. The box is also alot better looking than that ebay auction. I think that the price is very comparable to buying seperate components too! Probably get it done for under $500 for a single woofer.
dk
Darin Kaiser
11-06-2007, 02:16 AM
why dont you go to a local audio shop and get a box build they not that much
11-06-2007, 07:30 AM
I'm with tower and also suggest you go to a local audio shop as they do not charge all that much. Plus you get to have some input as to style etc. that you want them to pull off for you.
TAZ
11-06-2007, 01:32 PM
Ive got one 12" sub in mine in a square type box facing rearward behind the back seat (I dont run with the 3rd seat in place unless I know Im gonna be driving a bunch of people). If I need the storage space its set up to be quickly removed. I still have the stock bose system, I used a PAC interface to get the RCA signal for the amp...... the system sounds absolutely amazing and for the price you cant go wrong.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
11-06-2007, 09:07 PM
I have an sut, so i am limited on options, i went to one shop and they wanted $600 which i think it's steep, and thats just for the enclosure. i replaced my stock navi for the kenwood 8019 with navi, i replaced all the speakers with jl audio, and have a six channel jl audio amp. so all im missing is the subwoofer enclosure.
11-07-2007, 03:56 AM
THIS IS THE ONE I HAVE AN IT WORKS MORE THAT PERFECT PLUS IS LOUD
11-07-2007, 02:50 PM
Well that definately changes things and really limits your options. I would find a speaker that requires the very least amount of air space and see if you can build a box to fit under that seat that will support the requirements...... probably not gonna hit like a box in the rear of an SUV but will still sound very nice. Problem with the small enclosure speakers is that they usually need alot of power so you may be looking at needing another amp.
$600 does sound pretty steep but how elaborate is the enclosure they are building..... if its got some goofy cuts/molding then it could get up into that range. If you have access I would check a few more shops that are capable of that kind of work and see if you can get a better deal.
Good Luck
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
11-07-2007, 05:01 PM
Good Luck
Here is a box that I found:
http://www.subbox.net/store/catalog/...ars-p-108.html
It looks like it may be of higher quality, just from what I read.
dk
Darin Kaiser
11-07-2007, 05:37 PM
Is that a CPU you have there next to the speaker box? I'd love to hook up a satellite receiver or maybe even a computer.
11-08-2007, 12:41 AM
11-08-2007, 06:20 AM
yeah thats my office pc i was going to drop it off at bestbuy when i toodk the pix
2010 GRANTURISMO
2003 HUMMER H2
2008 SUZUKI GSXR 750
1996 HONDA CIVIC HATCHBACK AKA THE PROJECT
11-08-2007, 02:31 PM
that looks pretty cool at a greaat price. The one on ebay might be alright too!, but the pictures aren't very good. I would be more apt to buy this one.
dk
Darin Kaiser
11-08-2007, 02:36 PM
How about something like this:
http://www.elcovaforums.com/forums/s...ad.php?t=29867
Darin Kaiser
11-08-2007, 03:35 PM
Originally Posted by dkhummerh2
 YES!!!! That one is the best enclosure I believe I have seen to date. Very professional, sleek, and concealed. If it sounds as good as it looks, then that guy has got one helluva set-up.
11-08-2007, 06:00 PM
HAve you looked at the Rockford Fosgate upgrade taht is on SOMO?
I'm not the audio/vid guy, but that looked complete at a good price too.
Maybe they are not the same for output???? not sure.
03-27-2008, 06:17 PM
I installed 2 12" JL audio woofers yesterday and I am assuming they hooked it up via the rear left speaker wire. Using this device does it improve the sound drastically?
03-28-2008, 12:25 PM
I initially wired up my system using a line out converter from the rear speakers on either side of the rear gate, getting my signal from these speakers worked but I was not getting the very low range in terms of bass. I went ahead and ordered the interface (I have a similar one in my Z06) and it greatly improved the quality and range of sound, the interface is completely plug and play.
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
03-28-2008, 09:52 PM
Thanks! Is this the same interface PAC makes which you can use with your IPOD? I had this installed, but later removed because it was giving occasional background noise. Not sure if it is the same exact device, Do you have a link?
