Old 04-09-2008, 12:54 PM
homeboy homeboy is offline
homeboy is on a distinguished road
Default torsion bar ?
to those who have leveled by cranking torsion bars what is your set up as far as the measurement from the center of hub to lip of fender?mines at 24 inches,im getting a slight vibration at highway speed,tires were balanced yesterday so im ruling that out
Old 04-09-2008, 03:40 PM
Sheriff's Avatar
Sheriff Sheriff is offline
Sheriff is on a distinguished road
Default Re: torsion bar ?
My front came out to 23 7/8" (+/- 1/8"). I have had no issues w/ vibrations. Did you get an alignment after leveling? Are you comfortable that the shop did a good balance for you? Was your vibration before and after your balance? Tires old (how old?) or new? Just looking for some information to help identify your vibration issue.
Another thought...
There is a chance that your alignment might have been out of spec and you had uneven tire wear before you leveled and re-aligned your H3. If this was the case your tires may be "tracking" (wrong term?) wrong now causing your highway speed vibrations. Try rotating your tires and see if this corrects or changes the vibration.
I am BY NO MEANS a suspension / alignment expert. Hopefully, there will be some more responses to help you troubleshoot this issue!
Good luck!
2006 Victory Red H3
Magnaflow Catback Exhaust, K&N Filter,
Leveled w/Stock Keys, Bilstein Cognitos
"Life is not measured by the breaths we take, but by the moments that take our breath away"
Old 04-09-2008, 05:42 PM
after adjusting torsion bars i drove 25-30miles and then took it in for an alignment by a well respected local business,i still had vibration after recently rotating and balancing.i did my adj. at 20,ooo i now have 26,000.i think im going to drop it down an inch
Old 04-09-2008, 06:11 PM
Big Dad's Avatar
Big Dad Big Dad is offline
Wat rims are you running? The reason is, when I purchased my 3, the dealer had a horrible time trying to get my tires & rims balanced, and it caused a noticeable vibration that got worse as my highway speed increased. They ended up ordering new tires and then after that didn't fix it they swapped tires and rims.
They told me that they have more problems balancing tires on this type of rim.
Personally, I think it might have been a tire problem. I have never found any data on any Hummer forum that suggested there was a rim problem.
Old 04-10-2008, 12:49 AM
cdmintmi's Avatar
cdmintmi cdmintmi is offline
cdmintmi is on a distinguished road
very nice house Big Dad. I set mine at 24.25", got allignment and never rechecked becuase the 315 toyos fit about two months later and I didnt want to go any higher than neccesary. I did get it realligned after the tire were installed (package deal, basically free with mount and balance) and I had a slight pull to the right. now it seems worse and they said try rotating the tires. They only had 200 miles on them, I think im going to try and allignment somwhere else before my $1300 tires are uneven. No vibration though
