Old 01-31-2008, 10:25 AM
jecson jecson is offline
jecson is on a distinguished road
Default Remove the soldering
Hi, enjoyed the detailed explanation above on brazing. I have a question going in the reverse direction. How do you unsolder or unbraze a silver-soldered joint between stainless steel and brass without destroying optical components housed within?
Old 01-31-2008, 04:39 PM
ssgharkness020147's Avatar
Default Re: Remove the soldering
Where was there a thread about soldering/brazing? Either way the easiest way to remove solder is with a solder sucker, they can be found anywhere that has a good supply of electrical tools. As for the optical sensor, I'm not sure what you are referring to.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 02-07-2008, 07:51 PM
jacob.jacob0 jacob.jacob0 is offline
jacob.jacob0 is on a distinguished road
I don't know the answer to your question but I want to make a guess. Are you want information about brazing so you can go my link Induction Brazing thanks
Old 06-05-2008, 02:31 AM
zacknolden zacknolden is offline
zacknolden is on a distinguished road
Heatsinks are a must for the leads of sensitive components such as ICs and transistors.
Zack's Autopartswarehouse Blog
