Old 05-30-2008, 02:53 AM
Intercooled's Avatar
Intercooled is off the scale
Default Removing rear tire carrier
I think I would like ot remove the rear stock tire carrier. Is there a kit that is available to do this? what happens to the bolt holes? and where does the license plate go with light? (SUT, by the way.)
thanks
2006 H2 SUT Fusion Orange LE
Old 05-30-2008, 03:23 AM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
Default Re: Removing rear tire carrier
When you remove the tow hooks and brackets you will not be able to reinstall the swing arm as they are part of it. I went out and bought stainless steel hooks with 18,000lbs pull strength and made a license plate bracket out of 1/4 alu. The bracket can get mounted behind one of your tow hooks if you do it right.
if you just want to buy a kit
http://www.somo.com/H2-Spare-Tire-Ca.../rw600-4bc.htm
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
