Old 11-08-2008, 01:03 AM
meathook meathook is offline
meathook is off the scale
Default Need advise please Help?
thinking of purchasing a 2000 h1 wagon however there was some major engine work would you buy or pass ?
have copies of repair orders (3) regarding specific work we did here #422142; replaced injection pump driver#417608; change oil, ABS sensor replaced, replaced glove box assembly, right front hub reseal, replace washer pump, replace four (4) tires ($360x4) #413021 replace #7 piston and rod and replaced L/H cylinder head due to cracked seat-this repair order lists an extensive list of gaskets, seals, ring kit and fluids and more
CARFAX reports service (normal) 10/26/2000 at 228 miles, 12/05/2000 no odometer record, 01/09/2001 no odometer record, 01/19/2001 at 449 miles titled issued to first owner, 03/27/2001 at 3,965 normal service, 06/08/2001 at 7,053 misc service and brakes serviced, 10/19/2001 at 11,419 misc service and suspension system serviced, 02/21/2002 at 15,405 miles service and electrical system serviced, 04/26/2002 at 17,771 service, 07/22/2002 at 18,220, 08/30/2002 at 18,447 service, 10/24/2002 at 20,827 service, 01/16/2003 at 24,785 service, continues that way through 27K,29K,31K,33k,35k,36k,38k until 06/30/2004 at 40,949 miles normal service, then the next CARFAX note is 08/01/2006 at 52,968 normal service, 04/20/2007 at 53,270 sold at auction in PA and listed as dealer vehicle, 05/17/2007 at 53,522 sold at PA auction and listed as dealer vehicle. 09/22/2007 at 54,463 miles sold to Owner #2 and serviced 10/29/2007 in Allentown (not at Scott) no odometer recording. Traded to us approximately 3200 miles later.
thanks
Larry
