Old 08-28-2008, 04:46 PM
H3Eric H3Eric is offline
H3Eric is off the scale
Default Extended Warranty
Hi
I'm getting to 43K miles on my 06 H3, I believe it is 4 years (48 or 50K) miles as the basic warranty. Where do you think is the best place to get additional GM warranty?
Thanks,
Eric
Old 08-28-2008, 04:51 PM
Default Re: Extended Warranty
GOOD QUESTION !!!
You may, if you have had a lot of problems with one item (mine, its the repeating brake noise) try contacting GM Hummer direct and play VERY ANGRY CUSTOMER and see if it gets you an extended warrenty. It worked for many of the people who had the BAD HEAD PROBLEM...
Keep us informed
Old 08-28-2008, 05:27 PM
I did have the head replaced and have always had brake noise. Last week when I had a loaner (4K miles on it) it had the same brake noise. Maybe I should try to call GM.
Does anybody else have some good info, also what would be the best place to buy it?
GOOD QUESTION !!!
Keep us informed
Old 08-28-2008, 06:23 PM
Of course I also meant where is the best place to buy GMPP, I saw www.gmoutlet.com maybe there is better one out there?
Old 08-28-2008, 09:25 PM
do a search on this forum..........you will see where others have gotten a FREE extended warrenty............................!
use the search mode
Old 08-29-2008, 04:37 AM
What did you get as additional warranty?
use the search mode
